Author Topic: FS/FT: TWO Lacie Electron 22 Blue III Monitors  (Read 5134 times)
Daviea
  • Trade Count: (+30)
  • Last login:December 10, 2010, 06:51:56 pm
    • RAM Controls
« on: November 28, 2009, 05:56:54 pm »
I have two spare Lacie brand Electron 22 Blue III monitors.  These are huge flat CRT (tube) monitors.  Before LCD's took hold, these 22" monitors were the way to go if you were into 3D modeling.  They have a max resolution of 2048x1536 and on screen display features.  They were well cared for and work flawlessly.  I have no need for these any longer and wish to sell, trade or GIVE them away(if I have to).  These cost me $1200ea when I bought them new, so I'd like to see if I could get some value out of them, if possible.  I'm located in SoCal (Orange County area) and I would be willing to drop these off in-person.  I don't care to ship them - they're way too big and I don't have the original boxes for them anymore.... so shipping would be a pain.
I'd take any of the following items for the pair of monitors:
$100
a PSP
some Xbox360 games
some TIG welding accessories
a dual-link DVI video card (PCI-E)
4GB DDR2-800 RAM
Core i7 processor
Core i7 motherboard
triple channel DDR3 RAM for i7 Motherboard
... make an offer.
I don't want to store these, so if you're interested let me know and we'll work from there.
Dave
P.S.  Here are the specs:
GENERAL
* Display Type Display / CRT
* CRT Type Aperture grille
* Built-in Devices USB hub
* Width 19.5 in
* Depth 18.6 in
* Height 19.4 in
* Weight 67.2 lbs
* Enclosure Color Black , Blue
* Display (projector) image aspect ratio 4:3
DISPLAY
* Diagonal Size 22.0 in
* Viewable Size 20.0 in
* Dot Pitch / Pixel Pitch 0.24 mm
* Max Resolution 2048 x 1536 / 80.0 Hz
* Max Sync Rate (V x H) 160.0 Hz x 121.0 KHz
* Front Panel Controls Power on/off , OSD-position
* On-Screen Controls Color temperature selection , Language select , Convergence , Color adjustment , Trapezoid , OSD-position , Rotation , Contrast , H/V-moiré , Pin-balance , H/V-focus , H/V-size , H/V-position , Brightness , Zoom , Pincushion distortion , Video level , Geometry corner correction
VIDEO INPUT
* Analog Video Format None
* Analog Video Signal RGB
* Digital Video Standard None
AUDIO OUTPUT
* Type None
INPUT DEVICE
* Input device type None
EXPANSION/CONNECTIVITY
* Interfaces 3.0 x USB - 4 pin USB Type B - 3.0
* Connections 1.0 x USB - VGA - Mini-USB Type B - 1.0 , 1.0 x Display / video - 15 pin HD D-Sub (HD-15) - 1.0
MISCELLANEOUS
* Compliant Standards TCO '95 , Plug and Play , CUL , EPA Energy Star , MPR II , TUV GS , UL , ISO 9241 , CSA , NUTEK
POWER
* Power device form factor Integrated
* Voltage Required AC 110/220 V ± 10%
SOFTWARE/SYSTEM REQUIREMENTS
* Software type Drivers & Utilities
ENVIRONMENTAL PARAMETERS
* Min operating temperature 41 °F
* Max operating temperature 95 °F
* Operating humidity range 10 - 90%
Daviea
    • RAM Controls
Re: FS/FT: TWO Lacie Electron 22 Blue III Monitors
« Reply #1 on: November 29, 2009, 03:52:11 pm »
Ok, I see.
FREE
Local pickup only. I will NOT ship these.
However, I will deliver to you in the LA Basin area, but YOU pay for my gas.
Dave
daftspore
  • Last login:September 02, 2011, 05:48:43 am
« Reply #2 on: December 01, 2009, 07:12:00 am »
If anyone is looking for a good decent large monitor for a mame cabinet, these are fantastic. I have one in mine and the picture quality is amazing. They are obviously 4:3 as well so the correct aspect.
You often see them on ebay in the UK going for £100 but I managed to pick one up for £35.
  • Last login:February 09, 2026, 10:26:35 am
« Reply #3 on: December 01, 2009, 09:33:47 am »
If I was nearby I'd come get them, but alas, I'm in AZ.  Wanna take a road trip?   ;D
bdjou
  • Last login:June 10, 2011, 12:34:22 am
« Reply #4 on: December 03, 2009, 01:23:43 am »
Dave,
I'll take a monitor if you still have one. I can pick it up at your office. Let me know.
thanks!
