Author Topic: Rowe CD100 1989 model  (Read 2795 times)
slyder
  • Last login:December 15, 2009, 10:10:04 pm
« on: November 27, 2009, 01:20:16 pm »
I have a cable from the OBA-2 to eht bottom of the bill collector with a few wires pulled out.
I need a picture or a diagram of where the wires connect in the connector.
The end I need goes into the bottom of the collector.
Ken Layton
  • Guru
  • Technician
slyder
Re: Rowe CD100 1989 model
« Reply #2 on: November 30, 2009, 02:18:39 pm »
Thank you, I have found that but I have the cable and just want to fix that. I have 5 wires that have broke off. Colors are green, blue, smaller red, large red and a black that is in a jacket with a white and bare ground.
sequence across
1 - empty
2 - black
3 - red
4 - white
5 - yellow
6 - bare ground wire
7 - empty
8 - empty
9 - empty
10 - empty
11 - white
12 - empty
13 - empty
could someone tell me the sequence across the connector and I can resolder together.
Thanks :cheers:
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #3 on: December 01, 2009, 05:07:04 am »
Hi slyder,
At $19 for the loom that Ken has found on Ebay sounds a good deal, however if you go to the item link that Ken has listed you may be able to see the colours from the larger image on the listing.
Regards
Alan Hood
ami-man
UK
slyder
« Reply #4 on: December 01, 2009, 07:35:05 am »
Thanks, but I picked up this unit as a fix it project. I am doing this as a hands on repair. I bought a manual read through it, fixed it. This is the last thing to figure out.
I'm not really looking for the plug an play option.
This is like having a car to me. I definitely don't pay to have my oil changed.... I ask questions, read and figure it out then do it myself.
It's a learning thing for me.
Trying to keep the mind sharp.
mightytim99
  • Last login:September 05, 2011, 06:27:17 pm
« Reply #5 on: December 02, 2009, 07:30:44 pm »
Here's the Pics you requested. Hope it helps :)
slyder
« Reply #6 on: December 02, 2009, 08:45:59 pm »
Ahhhhhhh.
that's what I needed.
Your awesome, thank you very much.
I will resolder my connector tomorrow and hopefully it will work.
again thank you.
