Author Topic: Alternative to Sambers Hantarex POLO 28 STAR [EUROPE]  (Read 3465 times)
s34n
  • Last login:July 13, 2016, 01:30:42 am
« on: November 27, 2009, 12:11:21 pm »
Hi There,
I turned my cab on this morning, and the monitor doesn't receive any power.... i can hear a slight clicking sound from the board attached to the tube, i've had a few problems with this one anyway (problems), so I think its time to get rid!!
The cabinet takes a 29" screen, but I believe this one is 28"... my friend recently installed a tri-sync one into his, and the quality looks amazing...
Can anybody recommend a suitable replacement? I hear the kortek ones are good.... im in europe (uk), so whoever will deliver to there...
useless info... i use 640x480 interlaced @ 15khz (i dont know if this helps, im a software guy- not hardware, so its all a bit alien to me)
Sean
grantspain
Re: Alternative to Sambers Hantarex POLO 28 STAR [EUROPE]
« Reply #1 on: November 28, 2009, 03:19:46 pm »
difficult to find a tri sync that gives perfect geometry at 15khz,in europe the only one i know that is available is the sanwa pfx otherwise you can find wei ya or rodotron
sega had a few sanwa pfx left last week and i am told more are coming in,giz10p.co.uk have rodotron monitors in stock
grantspain
« Reply #3 on: November 30, 2009, 06:18:26 am »
the nanao ms9-29 give an amazing quality pic,they are only dual sync though(15/24khz)
s34n
« Reply #4 on: November 30, 2009, 07:39:28 am »
if i'm only using it for 15khz, that wouldn't be a problem would it??
the one i already have is 15/25khz right?
http://www.andysarcade.de/data/coinop/videogames/raster%20monitors/hantarex/polostar/service_manual_hantarex_polostar.pdf manual
grantspain
« Reply #5 on: November 30, 2009, 11:47:52 am »
normally the polostar are tri sync although i have seen 31khz star chassis,polo 2 are auto sync dual
the nanao will look very good with 15khz-just make sure you get one with no screen burn and insist on the seller powering it up with a grid test pattern and showing you the photos
