Author Topic: Q. for you Golden Tee players  (Read 895 times)
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
« on: July 20, 2003, 08:53:18 pm »
thinking about redesiging the control panel-- imagine a 90 degree cone, 45 degrees to left and 45 to right, in front of the trackball, beginning at center of trackball.  If I keep all sticks and anthing else protruding up from the cp outside of that cone, is that enough room to play GT and other trackball games?
or, do you wing the trackball around at greater angles than that?
thanks,
BobA
  • What Me Worry?
Re:Q. for you Golden Tee players
« Reply #1 on: July 20, 2003, 09:24:20 pm »
The cone should also extend behind the trackball or you will be smashing your hand into anything placed in the follow thru area.
BobA
