Author Topic: PC monitor to Jamma  (Read 1492 times)
sunkistshark
  • Newbie
  • Last login:January 06, 2010, 05:28:30 pm
PC monitor to Jamma
« on: November 25, 2009, 12:09:55 am »
I'm a newbie here building my first cabinet. I have a 19" pc monitor i've cut the cable exposing the 9 wires i'm not sure what each color is. I'm taking a guess that the red/blue and green corrispond with the red/blue and green connections on the jamma harness. But what are the other ones? I know i need to connect grounds and some sync ones.. but i dont know which is which. can someone help me plz.
Jack Burton
Re: PC monitor to Jamma
« Reply #1 on: November 30, 2009, 03:29:18 am »
The color of the wires of the VGA cable may or may not correspond to the colors on the jamma harness.
You will have to pin-out the cable yourself using a multi-meter.
What kind of PC monitor is this?  If the game you plan on playing isn't 31 khz or higher then you are going to have problems.
