Author Topic: Car Speakers???  (Read 1510 times)
numbnutz48
  • Last login:October 19, 2017, 04:30:39 pm
Car Speakers???
« on: November 23, 2009, 10:22:17 pm »
Does anyone have any experience mounting and using car speakers for their cabinet? I'm looking to buy a pair of 4" x 6" speakers  and wire them to a powered PC setup?
Suppose it will do the trick??
JONTHEBOMB
  • Last login:March 28, 2025, 11:39:04 pm
  • BOOM!!!!
Re: Car Speakers???
« Reply #1 on: November 23, 2009, 10:43:27 pm »
I used Sony X-Plod car speakers in my arcade cabinet.  From what I can remember mounting the speakers was not that hard.
Hope this article helps you out:
http://retroblast.arcadecontrols.com/articles/speakers.html
numbnutz48
Re: Car Speakers???
« Reply #2 on: November 23, 2009, 11:13:15 pm »
Sweet! Thanks for the article!
That's exactly what I was planning to do
protokatie
Re: Car Speakers???
« Reply #3 on: November 24, 2009, 03:52:04 am »
make sure to look at the Ohms rating on the speakers vs the amp. If they are too different then something will get hot (in the case of car speakers with a home amp, the speakers may be the things to get hot). I have never had a problem with this personally, but just a warning. Basically, don't crank the volume all the way up.
The reverse is true with using home speakers in a car, you can blow your car stereo that way as the amp in it will get too hot due to the higher resistance of the home speakers.
« Last Edit: November 24, 2009, 03:53:50 am by protokatie »
Blanka
Re: Car Speakers???
« Reply #4 on: November 24, 2009, 03:59:49 am »
Don't go with the oval ones. Its very hard to make a nice hole for them. Circles can be made perfect with a router.
MaximRecoil
Re: Car Speakers???
« Reply #5 on: November 24, 2009, 01:59:42 pm »
You are on the right track but you have things backwards. The higher the impedance of the speakers, the cooler the amplifier will run, because it is making less power. There is never a problem with using higher impedance speakers than an amp is rated for; in fact, it provides the amp with a nice and easy life. The downside is that your amp makes less power.
For example, a typical unregulated amplifer that is rated at 100W with a 4Ω speaker (typical car speaker) will only deliver 50W with an 8Ω speaker (typical home speaker). However, that same amplifer will deliver 200W with a 2Ω speaker (assuming there are no protection circuits to prevent it), which could be too much current for the components of the amp and cook it.
However, there are variables that tend to work in people's favor, preventing them from cooking their amp when using lower impedance speakers than the amp is rated for. For starters, music is dynamic, and with changing frequencies, you get changing loads; often substantially higher than the speaker's nominal impedance. Also, source units and amps tend to have volume/gain controls; which can be viewed as power controls. For example, an amplifier that "goes to 11", and makes 100W at "11", will only be making a fraction of that power at less than "11".
So, if you take an amp that is rated stable for 100W @ 4Ω, connect it to a big 2Ω resistor, feed it a 1 kHz tone, and crank everything to the max; you will probably cook the amp. However, if you hook it to a 2Ω speaker and play music or other dynamic forms of audio (as opposed to constant frequency test tones) at a reasonable volume, you probably won't harm anything.
« Last Edit: November 24, 2009, 02:21:39 pm by MaximRecoil »
bungy
  • Last login:February 06, 2020, 09:33:40 am
Re: Car Speakers???
« Reply #6 on: November 24, 2009, 02:10:58 pm »
You are on the right track but you have things backwards. The higher the impedance of the speakers, the cooler the amplifier will run, because it is making less power. There is never a problem with using higher impedance speakers than an amp is rated for; in fact, it provides the amp with a nice and easy life. The dowside is that your amp makes less power.
Thanks for this explanation, it is good to know.  I have a Logitech 2.1 system that came with 8 ohm satellite speakers which I've replaced with 4 ohm car speakers.  The volume is plenty loud at about 2, and way too loud at half volume.  It's been working great for a year so far, but I never even go near half power.
Namco
  • Last login:October 20, 2025, 05:55:49 pm
    • Freddo Mame Project
Re: Car Speakers???
« Reply #7 on: November 24, 2009, 03:11:06 pm »
Never go full re... power.  ;D
