Author Topic: Extremely stupid grounding question (JPAC).  (Read 2455 times)
chairhome
  • Last login:February 04, 2010, 10:07:32 am
« on: November 22, 2009, 10:50:23 pm »
Hi everyone,
I've finally gotten around to hooking my MAME cabinet back up after doing some moving around and trying to clean up the cab's insides... I had a question on grounding.  Do I need to hook a ground wire to the GND terminal on the JPAC or does that provide a ground for me to use on my switches.  I know its a dumb question :-/
Just trying to figure out why I can't get my controls to work right now, running winipac and it doesn't show any controls working.  I know I had a similar problem last year where I had a ground problem with my IPAC, but it was fixed... and now I can't remember what I did.  Thanks for the help, sorry if this is in the wrong section... I haven't posted in over a year!
swamprat96
  • Last login:January 10, 2012, 03:29:46 pm
Re: Extremely stupid grounding question (JPAC).
« Reply #1 on: November 22, 2009, 11:50:24 pm »
If I understand the question correctly- all the switches/joysticks etc need to return to the JPAC via a common ground wire. So if its an existing cabinet I would expect a common ground wire to your hardware would terminate at the Jpac
Thats if I understand correctly ;D
chairhome
« Reply #2 on: November 22, 2009, 11:56:03 pm »
Okay, thanks!
I currently have all Grounds on the switches terminating at the Jamma connector.  I'll patch it into the Ground terminal on the JPAC as well.  Thanks.
swamprat96
« Reply #3 on: November 23, 2009, 12:10:41 am »
OK I may be wrong. You are correct in that the ground is carried through the Jamma connection - but it still would not hurt to jump it and see if it fixes the issue. I was thinking Ipac not Jpac
chairhome
« Reply #4 on: November 23, 2009, 02:10:47 pm »
Well, my main question is: Do I need to ground the Ground terminal on the JPAC, or does it supply a ground connection for me to ground the other switches?  I'll try again today.
BobA
  • What Me Worry?
« Reply #5 on: November 23, 2009, 02:33:54 pm »
From the Ultimarc site
Check grounding of the cabinet before proceeding to avoid any danger/damage. The best method of doing this is as follows:
Using an ohmmeter or continuity tester check for a good connection between the following points:
Monitor frame
JAMMA edge connector ground pins. These are the 4 pins at either end of the connector.
Mains power cord ground.
Control panel ground.
Power supply ground if fitted.
chairhome
« Reply #6 on: November 23, 2009, 02:45:12 pm »
I read that, but I read it as saying that those points on the cabinet need to be grounded...
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #7 on: November 23, 2009, 04:09:06 pm »
If you are grounding your controls to the grounds on the JAMMA connector, you are fine.
Working: Not Enough
Projects: Too Many
Progress: None
chairhome
« Reply #8 on: November 23, 2009, 04:15:04 pm »
Thanks, so does that mean I have a different problem with my jpac controls not working?
CheffoJeffo
« Reply #9 on: November 23, 2009, 04:28:21 pm »
Do you get any lights on your JPac ? Can we see a picture of your wiring ?
Working: Not Enough
Projects: Too Many
Progress: None
chairhome
« Reply #10 on: November 23, 2009, 04:31:55 pm »
I get lights on my Jpac.  It works fine as the interface between the Arcade monitor and PC.  I guess my next step will be to connect the JPAC ground terminal to a ground and see if that gets the controls working in test mode.  Thanks for the help efforts, I'll post up pics of what I got later if I can't get it working.
chairhome
« Reply #11 on: November 23, 2009, 11:14:24 pm »
Never mind, got it working!  Thanks for everyone who was trying to help!
Eny-
  • Last login:December 19, 2013, 06:22:03 pm
« Reply #12 on: May 15, 2010, 11:24:55 pm »
How did you do it? I'm having the same problem. Thanks!
