Author Topic: is the connection on an arcade monitor different? or just the khz?  (Read 1536 times)
milkit
  • Last login:June 28, 2014, 09:14:33 pm
I was about to build a cabinet and use a TV but i just found a Blitz 99 cabinet fully working for only $375. Im thinking I might convert this instead.
To use this monitor, I should be able to just use VGA using a 15khz software correct (or an arcadevga card)? The physical connection is generic vga right?
thanks for a noob question!
bungy
  • Last login:February 06, 2020, 09:33:40 am
Re: is the connection on an arcade monitor different? or just the khz?
« Reply #1 on: November 23, 2009, 02:25:59 pm »
I'm not familiar with Blitz 99, but I think most arcade monitors use a different input than VGA.  I think Ultimarc's JPAC can convert your VGA input in something suitable for an arcade monitor.
Maybe try asking in the monitor forum?
speedklz
  • Last login:November 17, 2018, 12:56:23 pm
« Reply #2 on: November 25, 2009, 09:35:47 am »
You will have to do some cutting and soldering.  You have to splice into the harness that goes to the monitors chassis. You can make a vga break out cable.  http://forum.arcadecontrols.com/index.php?topic=83104.0
Best of the Best of the Best. Sir!
« Reply #3 on: November 27, 2009, 11:01:24 am »
your blitz cab might have a medium res monitor, you should find out the monitor model then post in the monitor section, either way you will probably need a breakout cable.
