Author Topic: Question: Bill Validator  (Read 1429 times)
austinrfnd
  • Last login:March 28, 2004, 06:13:42 pm
« on: July 20, 2003, 01:15:35 am »
I was on some the Virtual Music Jukebox forum.  and I read that the some Mars Bill Validators work by simply sending pulses to your coin 1.  LIke one DOllar will send 4 pulses to your coin 1.  Can anyone verify this?
-Austin
Felix T Cat
  • Last login:September 08, 2020, 08:48:29 am
Re:Question: Bill Validator
« Reply #1 on: July 20, 2003, 08:41:43 am »
I can but then again, I'm the same person that posted it on the VMJ forum.
As I posted there, make sure it is either a AE2411 or AE2611.  Both of these have an "always enable" mode so they can work with just 110v ac and send pulses out.  You can make a VN 2511 work but it's a little more in depth then flipping a switch
Felix T Cat
« Reply #2 on: July 20, 2003, 09:42:05 am »
Happ sells the complete mounting kit here.
http://www.happcontrols.com/index.html?http://www.happcontrols.com/validators/42320000.htm!
For those that want to make their own, Power (110v) goes to pins 4 and 6 of the 9 pin connector and the credit relay outputs on Pins 7 and 8.
Basically the when a bill is accepted there is a relay inside the validator.  It will pulse X number of times per $1.  If you wire the credit relay output to your coin in switch it will look like the coin switch is opening and closing.
Felix T Cat
« Reply #3 on: July 20, 2003, 06:15:34 pm »
