Author Topic: Makvision Monitor Issue?  (Read 1964 times)
gumby510
  • Last login:November 17, 2022, 09:19:44 pm
  • SR-20 NX 2000
« on: November 19, 2009, 03:21:04 am »
I just installed a Makvision m3129 in my cab running a ultrimac video card. I'm having some issues with some games causing a black screen once I load them up. It will lock up the computer in a black screen except for the windows hourglass. I can run Super Mario brothers and all neo geo np but once I load up Outrunners or galaga it bugs out. I hooked up a computer monitor and they ran fine. I'm a complete noob at these things as I read through like 20 pages in this forum before posting. what am I doing wrong? Please help as I spent alot of money on this monitor. Here is a video on utube I hope it works so you can see what I'm talking about.
grantspain
Re: Makvision Monitor Issue?
« Reply #1 on: November 19, 2009, 01:26:02 pm »
that is infact a wei ya 3129 monitor-max res is 31khz set your graphics card to the correct frequency 680 x 480
gumby510
  • SR-20 NX 2000
« Reply #2 on: November 19, 2009, 02:48:36 pm »
So Its supposed to be 680x480 and not 640x480? I also went into the advance display menu and the refresh hrtz was set at 200. I lowered it to 60. So should this be set at? I know a LCD monitor is usually 70 or so. I was figuring mame was not starting the right res for All games as some work perfect and others lock up the system.
ThAnks for the reply
grantspain
« Reply #3 on: November 19, 2009, 03:02:30 pm »
yes 640 x 480,it was a typo
refresh at 60hz i believe is correct-basically the most you want to feed this monitor is standard vga res and nothing higher
gumby510
  • SR-20 NX 2000
« Reply #4 on: November 19, 2009, 06:49:24 pm »
Ya it's set at 640x 480 now just don't know if this really is a monitor issue or a software/setup issue. Mrs pacman looks great but galaga blk screens out. I'm using mame32 as a frontend maybe I can try advmame or something else. Just kinda bumed as this monitor set me back a few bucks.
grantspain
« Reply #5 on: November 20, 2009, 11:45:19 am »
its not monitor,they tend to work or not
i would look into your mame settings
