Author Topic: Coin door help needed!  (Read 6735 times)
Nacimroc
  • Last login:October 20, 2015, 03:46:25 pm
« on: November 18, 2009, 09:13:58 pm »
Finally comming to the end of my build but there is one thing i cannot find. I'm trying to track down the coin reject bezel/button and coin return bezel and flap thingy. You can see it easier in the pic. Happ want a $50 minimum order + delivery to ireland which ain't cheap. Anywhere else i can get it cheaper? or anyone who has one that would sell ?
Ken Layton
  • Guru
  • Technician
Re: Coin door help needed!
« Reply #1 on: November 18, 2009, 09:52:21 pm »
You mean that you can't get these at Happ's UK office?
United Kingdom:
Suzo-Happ Group (UK) Ltd.
Units 1 & 2
King Georges Trading Estate
Davis Road
Chessington
Surrey
KT9 1TT
Phone: (+44) 208 391 7700
Fax: (+44) 208 391-7760
E-mail: sales@suzo.co.uk
Nacimroc
« Reply #2 on: November 19, 2009, 05:46:59 am »
Checked all the product pages and can't see it anywhere there. They sell the coin doors but not the bezels etc. I could have missed it but i looked pretty hard.
Franco B
« Reply #3 on: November 19, 2009, 06:12:42 am »
Send [divemaster127] a PM. He carrys 99% of Happs goods, has no minimum order value and is cheaper than Happs prices to boot.
His BST thread is sticked at the top of the page if you want more info.
enskpo
  • Last login:October 04, 2023, 10:19:34 pm
  • How did that happen?
« Reply #4 on: November 19, 2009, 09:32:43 am »
Lizard Lick has some Happ coin door parts:
http://www.lizardlick.com//pages/coin_doors_parts.shtml
Ken Layton
  • Guru
  • Technician
« Reply #5 on: November 19, 2009, 11:16:57 am »
For detailed parts, always click on "Mounting and exploded view" on the coin doors pages:
http://www.happcontrols.com/coindoors/40051200_exploded.htm
Kevin Mullins
    • Me on Myspace
« Reply #6 on: November 19, 2009, 12:22:57 pm »
Looks like it uses the same parts from this version..... minus the metal mounting plate.
http://www.happcontrols.com/coindoors/40002300p_exploded.htm
Search each individual part number in that exploded view.
I've had to do this for a few things before I could find anything on their site. (especially small individual bits)
For example - part # 42-7355-00D is listed on your coin door page, but there's no price, etc.
But if you "search" that part # you may find it listed elsewhere.
Or sometimes drop part of the part number in the search like the "00D" part, so just take that exploded view number and search "42-7355" if nothing comes up for "42-7355-00D".
Nacimroc
« Reply #7 on: November 19, 2009, 02:03:07 pm »
Thanks for help lads! Never noticed that before! Opens up a world of extra little things for me aswell!
Edit: Just ordered off divemaster127 in the BST section! He was alot cheaper (and good to keep business in BYOAC)
Thanks again! Delighted now!  :applaud: :cheers:
« Last Edit: November 19, 2009, 02:18:03 pm by Nacimroc »
Nacimroc
« Reply #8 on: January 08, 2010, 09:56:48 am »
Right! got them items and went to install only they dont fit! these are the official happ ones I ordered from divemaster! The coin insert bezel is too small and the coin reject is far to big! This is the last thing on my cab to be finished so I won't be content until its done! One thing I noticed is that the holes are offset to the left of the door, not like the happ doors! The one Kevin mentioned has the same item number as the main happ door one!
These wont be used for anything but cosmetic look so I don't mind glueing and doing a slap up job even if the size is wrong but too small is def a problem! The coin insert hole is 52mm x 52mm and the coin reject hole is 43mm wide x 32mm high!
Anyone got any idea! Pleeeeeeeeeease!!!
« Last Edit: January 08, 2010, 09:59:22 am by Nacimroc »
Silas (son of Silas)
« Reply #9 on: January 11, 2010, 05:04:02 am »
I'm guessing from the fact that you haven't thought of this yourself that you aren't a keen metalwork hobbyist? If it were me I would strip the door then:
The hole thats too small I would file/cut out larger.
The hole that's too big I would hold a piece of steel plate behind the hole, use the hole as a profile to draw onto the plate with a scribe the exact size of a blank to fill it, cut out and weld in the blank then re-cut a new hole of the exact size required.
Grit blast/prep the door and powder coat to the desired colour.
My Project MAME clone
Who is Silas?
Nacimroc
« Reply #10 on: January 11, 2010, 07:52:12 am »
Thanks for reply! Im def not a metalworker but I hadn't even thought of doing it that way! Think I might give it a go as I've no real alternative!
