Author Topic: Can I Swap Monitor Frames? Now With Pics!  (Read 1450 times)
urbecrisch
  • Last login:March 30, 2025, 01:11:38 pm
  • I was the S**T back in '82
« on: November 08, 2009, 03:00:18 pm »
I'm wondering if I can swap out one monitor frame to another?  Here's my situation:
I had a 25" arcade monitor running that went bad (PIC 1).  I picked up another 25" monitor (PIC 3) but the bottom frame bracket is 1.5" wider (from top to bottom) than my old monitor so it doesn't fit in my cab :badmood:
I'm wondering since it's the same size monitor if I can unscrew the top/bottom metal support frame and swap the two monitor's out so the new one will fit.  Has anyone done this before?
« Last Edit: November 08, 2009, 04:50:00 pm by urbecrisch »
MonMotha
Re: Can I Swap Monitor Frames? Pics coming soon
« Reply #1 on: November 08, 2009, 04:16:15 pm »
Usually quite possible since the "ears" that mount the tube are in the same place for a given size tube, but the chassis board may not easily mount to the new frame.
urbecrisch
« Reply #2 on: November 08, 2009, 04:40:58 pm »
The chassis are different but I think it's do-able.  I just want to make sure it's something that can be done or if I'm taking on an impossible task.
Also if I did swap out the frame, I would need to rotate the chassis on the monitor because the controls are in the front as you can see in the 4th PIC posted above.  This way I can shorten the frame up and still have access to the video controls.  Make sense?
« Last Edit: November 09, 2009, 07:35:27 am by urbecrisch »
