Author Topic: Sanyo Pro-X PLC-SW30  (Read 4062 times)
ark_ader
  • I glow in the dark.
« on: October 31, 2009, 05:45:25 pm »
Hi my projector is misbehaving.  The lamp replace light is not on, and last time it was on it was working fine but I ran it watching Benjamin Buttons so I do not know if it overheated.
How can I tell if it is the lamp or some internal thermal fuse?
When I switch it on the fans come on the power light turns green then it shuts down and reports a red light on warning.
I checked the lamp and it looks fine as I had only a few hours on it so far.
I use it for arcade games and the odd movie which I now miss.
Is the repair going to be expensive?
grantspain
Re: Sanyo Pro-X PLC-SW30
« Reply #1 on: November 01, 2009, 05:40:18 am »
projectors have a lamp life timer,if that was not reset to 100% when the lampo was last changed then it could throw up the red light and the bulb look fine
you should be able to meter the bulb
ark_ader
« Reply #2 on: November 01, 2009, 02:31:56 pm »
Yes that would solve the problem, unfortunately the projector switches off before I can get to the menu.  I have pressed the reset switch, so there must be something more sinister going on.  Its Christmas time, why not?  ;D
grantspain
« Reply #3 on: November 01, 2009, 03:01:50 pm »
all the projectors i have worked on had a proceedure when you change the lamp-eg hold down 3 buttons and power on
if you can find an instruction for replacing bulb perhaps there is a special sequence to follow
