Author Topic: Mala v.1.5 - BG Muzac Issue  (Read 5678 times)
mark_navigator
  • Last login:August 03, 2010, 04:20:11 pm
« on: October 30, 2009, 01:25:48 pm »
Hi,
looking at the new feature of Mala 1.5 version about intro video expanded in full screen mode, I got that having background music set to play, when Mala is loading the background music starts together with the intro-video, getting so a mixed audio!
Is it possible to correct that bug?
« Last Edit: November 29, 2009, 12:45:46 am by loadman »
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Mala v.1.5 - intro video bug.
« Reply #1 on: October 30, 2009, 09:08:37 pm »
I think you should try the beta to see if you still have the problem.
http://forum.arcadecontrols.com/index.php?topic=90230.msg964524#msg964524
mark_navigator
« Reply #2 on: November 02, 2009, 12:51:41 pm »
Right..........and the problem has been fixed, but another old problem come out again:
background music sometimes stops at the end of a track, instead of continue to randomly playing!
« Last Edit: November 02, 2009, 01:14:13 pm by mark_navigator »
SGT
« Reply #3 on: November 10, 2009, 07:55:52 pm »
How often does it happen? Have you tried turning on the debug log and see if there is an entry when it quits playing?  It's not the same track every time is it?  We may need to see if anyone can duplicate the problem so we can submit a bug report to loadman.
mark_navigator
« Reply #4 on: November 13, 2009, 01:14:09 pm »
I suppose it happens 1 time every 3-4 game lunching, but I didn't check with so long cycles.
I turned on log writing but I didn't see anything about sound stopping.
I'm not so sure, but I think it happens not with the same track and however, with Mala v.1.5 background music doesn't stops.
loadman
  • Moderator
    • MaLa
« Reply #5 on: November 14, 2009, 08:37:33 pm »
Yeah I know about the music bug...sorry
I annoyed me so much I have not enabled it for a while.
I have not got to it as I was focusing on the video issues first
mark_navigator
« Reply #6 on: November 16, 2009, 12:32:06 pm »
So with next release that bug should be solved?
If yes, how long time is still needed to get newer version?
loadman
  • Moderator
    • MaLa
« Reply #7 on: November 21, 2009, 04:34:13 pm »
Ask my wife  :laugh2:
I want it fixed too, it 'bugs' me.
I'm sure all it needs is a bit of time spent on it.
Sorry I am not able to give any time lines on this Project
mark_navigator
« Reply #8 on: November 23, 2009, 01:10:45 pm »
Sorry, but if Mala 1.6 is next to come out, why not get it fixed, specially if it needs a little bit of change?  ???
loadman
  • Moderator
    • MaLa
« Reply #9 on: November 24, 2009, 09:24:30 pm »
When I say a little bit,  I mean a little bit to work out solution but a couple of hours to implement and test.
Really just has not reached the top of the list yet (in order of priority) .. hang in there
loadman
  • Moderator
    • MaLa
« Reply #10 on: November 28, 2009, 06:02:31 am »
Can you give me some more info on this bug on your system?
Does it happen on the same track?
Is there some pattern to when this bug reveals itself.
I am trying to recreate it and it is not working for me right now:-(
I know there is a bug as I have seen it before, but any clues on how to make it happen semi consistently is required for me to squash the bug
In any case I am increasing the logging on BG Music so that may give some clues
« Last Edit: November 28, 2009, 06:15:35 pm by loadman »
loadman
  • Moderator
    • MaLa
Re: Mala v.1.5 - BG Muzac Issue
« Reply #11 on: November 29, 2009, 12:47:02 am »
Ahhhh ,
I have had it with the Audio.  I deserves the same treatment I gave to the video.. that is replace the engine.
That may sound a bit drastic but it will be much easier.  I have already started  ;D
mark_navigator
« Reply #12 on: December 07, 2009, 02:21:33 am »
Hi Loadman,
I want to tell you another bug found on 1.6b version:
when a game is launched and on for enough time, closing it to go back to Mala, it's running with the screensaver, so closing the game you get the screensaver not the layout screen. Is it just wanted or it's a bug? In my opinion it's better to get layout screen, so screensaver launching frozen when playing a game.
loadman
  • Moderator
    • MaLa
« Reply #13 on: December 09, 2009, 12:13:54 am »
Hi Loadman,
Do tell
The mala screensaver?  If so are you using it in video or picture mode.?
Is it a mame game or other emu or either?
mark_navigator
« Reply #14 on: December 10, 2009, 12:49:49 pm »
I'm using picture mode.
I discovered it launching mame game, but I don't know if it can happen with other non-mame games too.
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
« Reply #15 on: January 04, 2010, 07:37:38 am »
Like the rest of us, he has a day job and does the MALA project on his own time free of charge.  Like a famous game company once said "It will be done when it's done".
« Last Edit: January 04, 2010, 09:53:47 pm by loadman »
Galaga... Was there any other game?
loadman
  • Moderator
    • MaLa
« Reply #16 on: January 04, 2010, 09:54:06 pm »
I can't wait for Duke Nukem Forever
