Author Topic: Monitor switching  (Read 1766 times)
speedklz
  • Last login:November 17, 2018, 12:56:23 pm
Monitor switching
« on: October 27, 2009, 07:14:55 pm »
I have two WG 25k7131`s but they seem to have different monitors can I still switch the boards out with each other? Cause I have one with a bad board and one with bad burnin.
Best of the Best of the Best. Sir!
Kevin Mullins
    • Me on Myspace
Re: Monitor switching
« Reply #1 on: October 27, 2009, 09:33:07 pm »
Different TUBES you mean ?
(probably just manufacturer, like RCA or Zenith)
If the chassis is identical, meaning the circuit boards, then yes.
speedklz
« Reply #2 on: October 27, 2009, 10:28:17 pm »
Yea different tubes but the chassis are both 25k7131`s
speedklz
« Reply #3 on: October 28, 2009, 10:40:35 am »
I just dont want to blow anything ( or me) up with this switch..
grantspain
« Reply #4 on: October 28, 2009, 11:17:54 am »
check the neck cards have the same shape socket and you should be fine
Kevin Mullins
    • Me on Myspace
« Reply #5 on: October 28, 2009, 12:33:01 pm »
And discharge..... discharge..... discharge .....
speedklz
« Reply #6 on: October 28, 2009, 01:33:29 pm »
Yea that discharge crap scares the hell out of me ever time. Should I set the thing on wood or is it alright leaving it on the carpet when I discharge it. I just ground it to the frame, but I have never done this after I have removed the thing.
speedklz
« Reply #7 on: October 28, 2009, 08:40:41 pm »
and I am alright just using the screwdriver with the clip method.. Sorry but I usually wait weeks to do this and I dont have that kind of time now so I am leary of the Juice flowing through this thing.. :dizzy:
Kevin Mullins
    • Me on Myspace
« Reply #8 on: October 29, 2009, 12:19:49 am »
Yup, just clip one end to the screwdriver and the other end to a ground.
SirPeale
  • Green Mountain Man
« Reply #9 on: October 29, 2009, 08:56:40 am »
The best piece of advice I can give...relax!  Even though when you discharge there's a big *snap* there isn't much to it.  When it's running, however, that's another story.
As for the chassis, as long as both K7131 have the same neckboard you should be able to swap them just fine.
