Author Topic: Mamewah and NES EMU  (Read 2979 times)
jginiso
  • Last login:January 23, 2009, 01:41:17 pm
Mamewah and NES EMU
« on: July 17, 2003, 08:42:13 pm »
Ive been struggling to set up Nester, RockNESX, VirtuaNES etc. to work correctly in Mamewah. My problem is exiting the emu on ESC. Instead of going to Mamewah it goes back to the emu GUI. I tried them all but obviously only need to get one of them to work. Any help would be appreciated.
James
P4
WinXP
boarderguy41
  • Last login:August 05, 2004, 07:24:53 pm
Re:Mamewah and NES EMU
« Reply #1 on: July 17, 2003, 08:53:47 pm »
have you tried setting the NES emus to enter full screen mode when roms are loaded?
TalkingOctopus
    • My Arcade
« Reply #2 on: July 17, 2003, 10:15:28 pm »
You can make esc quit in the dos version of virtua nes by editing the config file.
In the windows version, you cannot set esc to quit, however, you can set another key up to exit.
visciouslymamed
  • Last login:December 02, 2011, 08:38:46 pm
« Reply #3 on: July 18, 2003, 12:13:45 am »
You can set ESC to exit in the windows version. First, setup the emulator and controls as you want them. Then open your virtuanes.ini and edit this line
[ShortCut]
TBL00=18402E4026403140204000000000000017401140000000000000000000002D4012
to this
[ShortCut]
TBL00=000000000000000000000000000000000000000000000000000000000000010001
Save the file and set the read-only attribute or virtuanes will overwrite the settings. ;)
jginiso
« Reply #4 on: July 18, 2003, 07:54:14 pm »
[ShortCut]
to this
[ShortCut]
Thanks Viscous this worked great!
Jakobud
  • Last login:December 09, 2025, 12:11:34 pm
« Reply #5 on: July 18, 2003, 11:57:57 pm »
Viscious...........that is brilliant.  How did you figure out that hack?  I saw all those keycodes in the ini but couldnt make sense of any of it.
« Last Edit: July 18, 2003, 11:58:27 pm by Jakobud »
TalkingOctopus
    • My Arcade
« Reply #6 on: July 20, 2003, 01:01:19 am »
zSnes is the same way.  You can set an exit key but not esc.  Do you know a work around for that as well?
Thanks alot for the virtuanes tip btw.
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« Reply #7 on: July 20, 2003, 01:19:12 am »
d/l zsnesfe the fe freindly version... thanx to wonderboy. heres a mirror
www.geocities.com/jakejake28
« Last Edit: July 20, 2003, 01:20:48 am by jakejake28 »
It's all about the Pentiums
