Author Topic: Nec RGB input and bnc cable question.  (Read 2209 times)
SNAAAKE
  • -Banned-
« on: July 17, 2003, 07:57:36 pm »
OK,my monitor have rgb input.
R,G,B,hs,v
the monitor is multi sync.
Can I run vga using this cable?
The back on the monitor look like this.
or the rgb input ONLY outputs 15khz?
anyone?  :)
See I use a switch box to switch between dreamcast and pc.
I wanna use my remote the switch.
there is 2 vga sockets(15pin) but the bottom one is "vga output".
The switch box works and all but still annoying.why would I use if I can switch with my remote :D. anyhey.....
« Last Edit: July 17, 2003, 08:03:05 pm by SNAAAKE »
J_K_M_A_N
Re:Nec RGB input and bnc cable question.
« Reply #1 on: July 18, 2003, 01:23:33 pm »
Yes Snack ;) , you can use that cable. That is used for RGB2. RGB1 is for the 15 pin VGA connection. Depending on where you buy that VGA->BNC cable, it could cost you. Look for a cheap price. At best buy it is like $40 but elsewhere online it is like $10-$15. I would have to look at mine when I get home to see about the 15khz. I think it is 30khz also though. Good luck.
J_K_M_A_N
SNAAAKE
  • -Banned-
« Reply #2 on: July 18, 2003, 02:05:58 pm »
oh hey... :)
is there a way you can be sure it does 31 khz ?  ???
Dont wanna burn anything AND I had really bad monitor experience before so make sure and post back.
(thanks for that remote again..working great ;D)
J_K_M_A_N
« Reply #3 on: July 18, 2003, 03:39:00 pm »
I will check my manual when I get home.
J_K_M_A_N
J_K_M_A_N
« Reply #4 on: July 18, 2003, 05:49:07 pm »
Well, according to my manual, it says:
Synchronization
Horizontal               15.5 - 38 kHz (Automatically)
Vertical                    40 - 100 Hz (Automatically)
So, yes, it should be fine at 31Khz. Good luck.
J_K_M_A_N
