Author Topic: MINWAH...i need your help  (Read 1732 times)
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« on: July 17, 2003, 10:32:28 am »
alright, i finally got my mame stuff working through mamewah, and even my NES emulator, but when i try to push ESC, of course like many peoples it only cuts off the full screen of the emulator and doesnt return me to mamewah itself.  this is only my NES emulator that is doing this.  i am using FCEultra.  i have virtualNES and Nester and Nesticle and all that crap that i can use, but virutal NES gives me problems, it wont start for some reason.  anyway, is there a way to get FCEultra to close when i push ESC?
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:MINWAH...i need your help
« Reply #1 on: July 17, 2003, 10:54:14 am »
I am not Minwah... and I'm not actually sure...
but I believe howard C's command line wrapper thingies help make other emulators behave more like Mame i.e. more FE friendly...
*shrug*  http://www.oscarcontrols.com/lazarus/  i believe
rampy
hulkster
« Reply #2 on: July 17, 2003, 11:24:55 am »
do these work for mamewah as well?  i dont want to switch FE's.
rampy
  • *shrug*
« Reply #3 on: July 17, 2003, 11:32:56 am »
they are FE independent... they are mearley wrappers that alter the functionality slightly of some  less cabinet friendly emulator(s) in order to make them more FE friendly (in general)
*Shrug*  note: I haven't bothered to get my NES/etc games setup on my cabinet yet so I haven't had to wrestle with this first hand, but it's my undersatnding as to it being hte well traveled path... you could also consider a differen NES emulator...
rampy
TalkingOctopus
    • My Arcade
« Reply #4 on: July 17, 2003, 12:08:47 pm »
VirtuaNES allows you to specify the exit key.  In the dos version you can edit the cfg to make esc exit.
I am using virtua nes with mamewah on my cab.
« Reply #5 on: July 17, 2003, 01:33:22 pm »
What those guys said ^
hulkster
« Reply #6 on: July 17, 2003, 04:01:00 pm »
k, so if i go download those wrappers...first of all which one, and where do i put it?  in my folder with the emu .exe?
hulkster
« Reply #7 on: July 18, 2003, 12:48:27 am »
nevermind
« Last Edit: July 18, 2003, 12:49:37 am by hulkster081 »
« Reply #8 on: July 20, 2003, 06:52:39 pm »
nevermind
Did you figure it out...or was that sarcasm? :)
hulkster
« Reply #9 on: July 21, 2003, 10:37:34 am »
well i just switched emu's.  i switched to virtualNES...it wasnt working cuz i didnt have any sound hooked up.  but once i did, it worked.  im at a different computer right now, but on tuesday ill be able to troubleshoot more closely and ill report stuff then.
