Author Topic: Can't Change Crosshair graphics  (Read 3462 times)
KonkeyKong
  • Last login:October 10, 2021, 09:57:07 pm
  • Monkey is my business and business is good.
« on: October 15, 2009, 07:37:25 pm »
It's built into the "tab" menu, yet it only gives me DEFAULT.  I've created a  crsshair directory in the artwork folder (tried it in the main folder too) with different png files.  Can't find any other info as to what to do.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Can't Change Crosshair graphics
« Reply #1 on: October 15, 2009, 08:06:11 pm »
What version mame?  Older versions did it differently, and older still couldn't.
Edit: link on pre 0.131 mame
« Last Edit: October 15, 2009, 08:07:42 pm by u_rebelscum »
Robin
Knowledge is Power
KonkeyKong
« Reply #2 on: October 15, 2009, 09:46:07 pm »
Opp, sorry 'bout that, using MAME 0.134
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: October 16, 2009, 01:29:34 am »
Okay, sounds like you're trying it the right way for the right version.
Did you read the crosshair part of Mr Do's artwork page?  Does the mame.ini name match the crosshair folder name?
Robin
Knowledge is Power
KonkeyKong
« Reply #4 on: October 16, 2009, 08:23:40 am »
Yup yup, read Mr Do's...  Can't find anything in my ini file relating to crosshairs.  Do I need to add a line of code?  I'm pretty savvy with changing what's already there, but I've never added anything new.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: October 16, 2009, 02:13:12 pm »
hmm... (looks at my mame.ini) ...
There's
crosshairpath             crosshair
near the top in the first section, "CORE SEARCH PATH OPTIONS" (in mame 0.134).
If your's is the same, that means either changing it to "crosshairpath crsshair", or changing the folder name to "crosshair".
Robin
Knowledge is Power
KonkeyKong
« Reply #6 on: October 16, 2009, 03:44:44 pm »
makes me wonder if I've got an older ini file in my folder...
I'll try trashing the old one, and see if a new one has the crosshairpath.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #7 on: October 16, 2009, 03:47:08 pm »
Just add the line to your INI.
KonkeyKong
« Reply #8 on: October 16, 2009, 04:46:59 pm »
even easier ;D  Thanks fellahs!
is there anywhere to get a list of all the available command lines one could add to an ini file?
« Last Edit: October 16, 2009, 04:48:49 pm by KonkeyKong »
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #9 on: October 16, 2009, 06:24:59 pm »
Well, there are the files in the docs folder.  You'd be more inrested in config.txt and windows.txt.  All options and details about them.
You can automatically update an .ini file in mame with mame -cc.  I'll leave all valid options in place, remove all invalid options, and add the missing ones with their default values.
edit: added verb :-[
« Last Edit: October 16, 2009, 06:32:14 pm by u_rebelscum »
Robin
Knowledge is Power
