Author Topic: Sega Model 2 Emulator Requirements  (Read 16575 times)
The Monkey Man
  • Last login:May 05, 2010, 11:01:20 am
  • The original Monkey Man
    • Super Mario Forums
« on: October 15, 2009, 03:56:09 pm »
Okay, so I'm constructing a MAME cabinet, and am trying to get some Model 2 games on it, like Daytona USA, Sonic the Fighters and House of the Dead.
Unfortunately, the Model 2 emulator doesn't work.
I've tried it on my main computer and it works fine, and I copied the roms and files to the arcade via a USB memory stick, but when I run it on the arcade system, it "experiences a problem and needs to close".
Not sure about the specs yet, but the graphics card is NVIDIA GeForce MX 4000. It's kinda goofy, because it loads N64 games, but no M2...
So, I'm just wondering what the requirements are to run Sega Model 2 games on your PC.
:) The Monkey Man
Re: Sega Model 2 Emulator Requirements
« Reply #1 on: October 16, 2009, 04:58:36 am »
It needs Pixel Shading v2 I believe...not sure if you video card can do this (?)
romshark
  • Last login:November 13, 2025, 05:36:05 pm
  • Arcade and Robotics enthusiast
« Reply #2 on: October 16, 2009, 11:31:13 am »
Can't find anything on their homepage about system requirements.
There's both a regular and multi-cpu version of the emulator (both in the same directory / download, so you should have both). Did you try both of them?
Did you make any changes to the .ini file? Maybe some tweaking is in order.
I've run it under both regular XP and Vista 64-bit, so the OS shouldn't be a factor.
TeutonicDarkness
  • Last login:July 16, 2019, 10:54:16 pm
« Reply #3 on: October 16, 2009, 11:45:29 pm »
 Well I'm not sure on the requirements...
but I Video card Doesn't  even have Pixel Shader 1!
Sounds Like things didn't copy over well or something else
is the culprit!
The Monkey Man
« Reply #4 on: October 17, 2009, 03:38:24 am »
Okay, it's probably a video card problem.
I found a new one online, will this one do?
SPECS:
Product Description: PNY Verto GeForce 6200 AGP - graphics adapter - GF 6200 - 256 MB
Device Type: Graphics adapter
Enclosure Type: Plug-in card
Interface Type: AGP 8x
Graphics Processor / Vendor: NVIDIA GeForce 6200
Core Clock Speed: 350 MHz
RAMDAC Clock Speed: 400 MHz
API Supported: OpenGL 1.5, DirectX 9.0c
Video Memory Installed ( Max ): 256 MB - DDR SDRAM
TV Interface: TV out
System Requirements: Microsoft Windows NT 4.0 SP6, Microsoft Windows Millennium Edition, Microsoft Windows 2000 / XP
Manufacturer Warranty: 3 years warranty
Marcade
  • Last login:March 12, 2012, 04:58:53 pm
« Reply #5 on: June 04, 2011, 08:54:43 am »
RISE FROM YOUR GRAVE...
So I'm sorry about dragging up an old thread but as it's on topic I thought it best to keep all the information possible together to help people with future searches. :)
I have these specs:
Memory (RAM):          1024 MB
CPU Info:              Intel(R) Pentium(R) 4 CPU 2.80GHz
CPU Speed:             2821.2 MHz
Sound Card:            SB Live! Wave Device
Display Adapters:      NVIDIA GeForce 6600 GT | NetMeeting driver | RDPDD Chained DD
I cannot get the emulator to run, I put all the rom files in the rom folder that is named correctly etc, double click on the exe and the little window opens up, I select daytona usa, the window resizes and crashes.
Is my system good enough to run it? is it me doing something wrong or just too weak of a computer?
On the other side of the screen, it all looks so easy...
Marcade
« Reply #6 on: June 04, 2011, 09:40:12 am »
FIXED IT ;D
DAYTONAAAAAAAAAAA!!
Basically found out that there was a problem with direct x on my system and the model 2 emulator is very VERY picky about directX.
Reinstalled direct x and BINGO.
It's slightly stutters but it's very playable on my system ;D ;D
Just posting as hopefully this information will help someone else out in the future  ;D
