Author Topic: Anything I can do to change my panel?  (Read 748 times)
RedSquirrel
  • Last login:September 18, 2003, 12:07:55 pm
« on: July 16, 2003, 06:10:16 pm »
I have pretty much made my panel, but only today released something.
Basically the panel is totally flat. I was going to angle it slightly in the cab. But it was only till today I realised if I do this, its not going to stay straight against the cab.
I could
a) just keep it flat
b) sand down the sides and front and make a small angle. (the hinge would be okay with this right?)
Any other ideas? Thanks
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
Re:Anything I can do to change my panel?
« Reply #1 on: July 16, 2003, 08:53:16 pm »
Really need to see some pictures of the CP and cab and how they go together now.
:) Rotate or die! :)
night
  • Last login:January 09, 2018, 02:08:19 pm
« Reply #2 on: July 16, 2003, 09:27:16 pm »
you mean the back edge against the cab sides right  ?
if you are using mdf and have or can use a small palm sander, the stuff sands down really fast and u can bevel the side enough to make it look better
