Author Topic: 'Shifted' buttons in MAME?  (Read 1391 times)
whines
  • Last login:June 10, 2024, 04:34:10 pm
« on: October 08, 2009, 09:17:46 am »
I have a pair of pushbuttons located on my coin door that I use for PAUSE and EXIT. (the coindoor has a space for a bill changer--I removed that plate and added a little one to put the buttons in, so it looks nice) These are wired to a hacked gamepad which also gives me the COIN lines.
Is there a way to tell MAME to interpret only BOTH buttons being pressed together as 'EXIT'? It hasn't happened yet, but I'm nervous about someone kneeing it in the middle of a game. When I first put it together I thought you could do that, but it's not letting me, as far as I can tell. Do I need to manually edit the config file?
Ginsu Victim
  • Last login:June 28, 2025, 10:45:55 pm
  • Comanche, OK -- USA
Re: 'Shifted' buttons in MAME?
« Reply #1 on: October 08, 2009, 09:34:41 am »
Go into the TAB settings, controls (general), and set CANCEL UI by pressing pause and exit at the same time.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: October 08, 2009, 12:32:14 pm »
Yes, Mame does "and" combos.
It's a little different than shift keys.  With shift keys, the 'shift' key need to be pressed and held first, then the other 'shifted' key pressed.  With mame's "and" combos, you can use any number of buttons, and as long as mame sees both (all) pressed at the same time, it will count as that input.
Ginsu posted how to map your request.
FWIW, mame can also do "not" combos.  More details at mamedev FAQs.
Robin
Knowledge is Power
Ginsu Victim
« Reply #3 on: October 08, 2009, 12:42:21 pm »
You know, I was scared I might give too short of an answer, but yours was surprisingly short as well. You're slipping. ;D
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: October 08, 2009, 07:48:42 pm »
 :blah: :blah: :blah: :blah: :blah: :blah:
Robin
Knowledge is Power
whines
« Reply #5 on: October 08, 2009, 11:25:47 pm »
I was sure I'd tried that, but apparently I hadn't because it worked just fine! Thank you! :)
Ginsu Victim
« Reply #6 on: October 09, 2009, 08:32:37 am »
Glad you got it working.
