Author Topic: WTB: Golden Tee Fore 2003 Hard Drive  (Read 1281 times)
dieseldogpi
  • Last login:October 27, 2011, 02:40:41 pm
« on: October 06, 2009, 12:22:36 pm »
My hard drive keeps resetting.  Anyone got one for sale that doesn't reset? PM me.
Kevin Mullins
    • Me on Myspace
Re: WTB: Golden Tee Fore 2003 Hard Drive
« Reply #1 on: October 06, 2009, 02:41:46 pm »
Have you checked your power supply and such ?
Typically a pcb resets.... not the hardrive. (i.e. the game is re-booting)
dieseldogpi
« Reply #2 on: October 06, 2009, 03:41:01 pm »
yeah, voltage is fine.  Its the pcb resetting because of the hard drive image (i believe).  I refer you to this:
http://www.cgcc.ca/forum/viewtopic.php?t=18846
I checked the power going to the drive previously, it was fine.  I checked at other points on the harness and they were where they should be.  Before my last hard drive went, everything was fine, then the drive physically broke, now the new drive (2 different drives from the same guy) it keeps resetting.  Is there another spot I should check voltage?  Should I move this to a different forum, I don't want to be in the wrong forum.
Kevin Mullins
    • Me on Myspace
« Reply #3 on: October 06, 2009, 06:45:05 pm »
Nope...... just like to make sure it's something you need. Especially when I saw "resetting" involved.
With you getting two bad drives from the same guy sounds just like the link you posted, same image, same results.
dieseldogpi
« Reply #4 on: October 07, 2009, 08:50:56 pm »
No one?  Really need to find a hard drive with a good image on it.  Any one with a back up??
