Author Topic: LedWiz config question (Update: Anyone?)  (Read 2599 times)
mark6437
  • Last login:March 23, 2020, 03:20:11 pm
  • THB2
« on: October 05, 2009, 05:20:34 pm »
Ok. I am going to be installing my LedWiz soon. Prob this weekend. Here is my question as I am new to led's.
I keep reading about RGB. I think it means red green blue? But I am not sure. I downloaded the ledwiz plugin and I am reading the install instructions.
I came accross this:
For instance, if my PLAYER 1 COIN RGB LED is wired into inputs 1,2,3 on my
  LEDWiz, I would:
  + Select P1_COIN on the left listbox.
  + Be sure that P1_COIN is CHECKED.
  + Then select LED Type of RGB.
  + For R input, I would select 1.
  + For G input, I would select 2.
  + For B input, I would select 3.
Can someone explain what RGB is? Because I am going to have no idea what to select, 1, 2 or 3.
Thx
Mark
« Last Edit: October 07, 2009, 04:46:52 pm by mark6437 »
ivwshane
    • My first mame cab! (WIP)
Re: LedWiz config question
« Reply #1 on: October 05, 2009, 05:51:50 pm »
You are correct, R=red, G=green, B=blue.
mark6437
  • THB2
« Reply #2 on: October 05, 2009, 07:02:53 pm »
Ok I am confused then. So if I want a Red light I pick #1? I thought the LED was a white light and the color of the button determined the color? I know that sounds confusing but I am cornfused too hahah
Thx
Mark
ivwshane
« Reply #3 on: October 06, 2009, 01:00:29 am »
I'm not sure what you are having problems with (you are confusing me now:p)
Here is what mine looks like:
1,2, and 3 represent the wire that connects to your rgb drive (I'm assuming you bought these: http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=83&products_id=240)
You will have to do a quick test to find what order the wires are in but my setup looks like the attached pic.
« Last Edit: October 06, 2009, 01:05:06 am by ivwshane »
mark6437
  • THB2
« Reply #4 on: October 06, 2009, 08:03:50 am »
No I didnt order that.
I have the LedWiz and the NoveGem buttons from GGG with the led. I have blue, clear, and red buttons.
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=73&products_id=281
Thx
Mark
« Last Edit: October 06, 2009, 08:05:50 am by mark6437 »
