July 29, 2010, 09:49:45 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
mamemarquees.com is now gameongrafix.com - new name, same great products and more! Click to see what's new!
   Home   Help Arcade Search Login Register
Main Woodworking Reviews Software Monitor/Video
Audio/Jukebox/MP3 Project Announcements Artwork Consoles Buy/Sell/Trade
Arcade Miscellaneous Everything Else Politics n Religion Forum Discussion Wiki Discussion
DOS/WinCab PowerMAME SK Jukebox UncleTs Jukebox Project Arcade
Linux Restorations Pinball MaLa Frontend controls.dat
Maximus Arcade Old Boards Old Archives
Unread posts | New Replies | Recent posts | Arcade | Rules | Chatroom | Wiki | File Repository | RSS
Pages: [1]   Go Down
  Send this topic  |  Print
Author Topic: Star Wars Cockpit (Rebuild)  (Read 1272 times)
speleo_de
Trade Count: (0)
Jr. Member
Offline Offline
View Profile
« on: October 04, 2009, 02:23:23 PM »
Got some time to take care of my Star Wars Cockpit that sat around in pieces for a couple of years.
Introduction
Reason for disassembling & rebuild was the bad condition and overall weakness of the structure. In this thread I hope to share out regularly the progress of getting the whole cabinet to buildup again. Maybe not something for the purist, as I will manufacture a good amount of the cabinets' wood/particle board. Also I will use woodplugs in combination with particleboard screws to be able to take it apart (at least a couple of times).
If you want to get the whole story so far (2004 - 2009) ...  http://www.andysarcade.de/projects_sw.html
If you want to se the pictures of disassembling (2004)   ... http://www.andysarcade.de/data/picseries/sw_restore/overview.html
Building the base assy
The last couple of weeks I have put together my shopping list of black covered particle board and plywood mainly, wood glue and particle board screws. Having the original cab as a reference made things pretty easy. I have first build the bottom frame from 3/4" (19mm) plywood, only challenging thing was to cut the various angles, as I don't have a circular hand saw  Smiley so I used a setup/tool where I can cut the angles with my router. The original rollers (including screws and nuts) have been cleaned, greased and reused. The bottom part of the base assy will just be screwed, the upper part with the connecting side strips are glued together. The large holes for the rollers/wheels were also cut with a router.
« Last Edit: October 05, 2009, 02:09:44 PM by speleo_de » Logged
speleo_de
speleo_de
Trade Count: (0)
Jr. Member
Offline Offline
View Profile
« Reply #1 on: October 05, 2009, 02:38:09 PM »
Continuing ....
Building the Sides
Trusting in the reproduction of the sideart by Thisoldgame, I have decided to rebuild the sides and apply the new sideart when it becomes available. There are two identical pieces for each side (total 4) plus the arches that I want to re-use. The arches are in a very good shape and not so easy to reproduce... The arches are used to connect the large front side with the small rear side ( front means : in flight direction ). The position of the sides versus base and arches is guaranteed by additional wood plugs, stability maintained by screws/glue. The old sides are being kept, just in case.
The new sides are being 'copied' with a router and by using the original sides as a master. The new sides are made of particle board and before routing, are roughly being cut to size with a jigsaw, this relieves stress from router and carpenter Smiley . The original side needs to be cleaned of nail, old wood, glue & old T-Molding, so that the router can move smoothly and the trimmer (right word?) can follow the curves. Some additional effort is required where the old sides are structurally weak. Here we can not simply copy the old / broken edges.  I've build a sort of template with 6mm birch plywood, that I 'copied' to the new sides. The second new (identical) side is copied from the first one.
Logged
speleo_de
speleo_de
Trade Count: (0)
Jr. Member
Offline Offline
View Profile
« Reply #2 on: October 05, 2009, 02:52:35 PM »
Continuing ....
Assembling Base and Sides
It's time to leave the garage, there's simply not enough space. The cab will be assembled, lying on its side. Some wood strips between ground and sides avoid scratches. Starting with the right side, the three pieces making up one side are positioned and wood plugs are fitted to be able to take it apart for transportation (just in case...). Same positioning and woodplugs for the other side. Then everything is screwed together. The first board that was screwed in (foot room) gave sufficient stabilty that the cab can now be rolled around. Looks already like a SW Cockpit, doesn't it?
Logged
speleo_de
hatrick
Trade Count: (0)
Full Member
Offline Offline
Big Brother is Watching You!
View Profile
« Reply #3 on: October 05, 2009, 03:56:56 PM »
Nice work. I'm anxious to see the finished results!
Logged
Level42
Wiki Contributor
Trade Count: (+5)
Full Member
Offline Offline
A Suzo stick is a joy forever...
View Profile
« Reply #4 on: October 05, 2009, 04:08:30 PM »
Looking great so far Andreas ! Really glad to see the progress !!!
Think about the goal, installing that minty fresh Amplifone tube in there as the last part and firing it up..... pure bliss Cheesy
Logged
Ms.Pac Man, Video Pinball, Joust, Berzerk, Pleiads Cocktail, Galaxian, Centipede, Mario Bros., Star Wars Cockpit, Puckman (bootleg), Space Invaders, Power Drift, Asterock (Asteroids bootleg)
ckong
Trade Count: (+1)
Full Member
Offline Offline
Retro Games forever!
View Profile
« Reply #5 on: January 09, 2010, 07:41:11 AM »
That looks very nice already. But where did you get the black covered particle board? Never seen that.
Logged
speleo_de
Trade Count: (0)
Jr. Member
Offline Offline
View Profile
« Reply #6 on: January 11, 2010, 11:52:43 AM »
...  where did you get the black covered particle board? Never seen that.
Easy enough - got it from my 'local' wood supplier. Its particle board with a "black pearl decor". A quare meter costs ~21 Eur when they cut it to size for you.
Logged
speleo_de
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
Page created in 0.182 seconds with 22 queries.
