Author Topic: Standard Jamma Video Connector to Hantarex 9000  (Read 2633 times)
mooro
  • Last login:December 06, 2009, 03:28:35 pm
« on: October 02, 2009, 02:18:41 pm »
Hi Guys,
Noob here so be gentle. Bought an old non dedicated cab that I am now converting to a fresh mame install. Just about getting there, but decided to redo all the wiring.
My new jamma loom arrived today, but the video has a 5 wired/pinned connector, whereas the connector currently into the hanterex chassis is 6 wired.
Any idea of what I do here? Just splice the new wires into the old like for like, or is there more to it then that??
Cheers,
mooro
grantspain
Re: Standard Jamma Video Connector to Hantarex 9000
« Reply #1 on: October 02, 2009, 03:27:29 pm »
the mtc9000 has an extra connector for vertical sync
connector on mtc is
1-red
2-green
3-blue
4-video ground
5-vertical sync
6-horizontal sync/composite sync
use horizontal sync
mooro
« Reply #2 on: October 02, 2009, 03:46:03 pm »
connector on mtc is
1-red
2-green
3-blue
4-video ground
5-vertical sync
use horizontal sync
Thanks for that. Are you saying then I can do away with vertical synch?
Or do I put both vert/horizontal synch wires into the composite synch pin?
grantspain
« Reply #3 on: October 02, 2009, 04:35:18 pm »
i would connect both vert and hori to the comp sync but you can do both options
hantarex can be picky on vert sync on namco and snk stuff btw-if you do get a problem with vert rolling then connect a 5k resistor from the vert sync pin to video ground on the actual monitor signal plug
mooro
« Reply #4 on: October 27, 2009, 09:49:05 am »
Thanks for your help Grant. Worked fine with just the comp/horizontal synch.
