Author Topic: Street Fighter Sound Problem  (Read 4855 times)
jeff412
  • Last login:April 04, 2012, 09:53:56 pm
« on: September 21, 2009, 07:32:56 am »
I have a Street Fighter 2 CE but I can't seem to get the sound to work.  I've tried the obvious.  The speaker wires are connected.  I can hear a low hiss in the speakers, so I know they're getting power.  I've tried adjusting the volume pot.  I can't seem to find a volume adjustment in the game settings.  Is there one?  Does anyone have any suggestions?
Jeff
sarge
  • Last login:April 27, 2015, 01:42:54 pm
Re: Street Fighter Sound Problem
« Reply #1 on: September 21, 2009, 10:13:19 pm »
Have you measured your 12V output from your supply?
jeff412
« Reply #2 on: September 21, 2009, 10:50:31 pm »
Yes.  It is 12.7 V.
Kevin Mullins
    • Me on Myspace
« Reply #3 on: September 21, 2009, 11:03:21 pm »
Did you try the volume pot on the pcb itself or were you just referring to a cabinet volume pot ?
jeff412
« Reply #4 on: September 22, 2009, 07:39:26 am »
The one on the PCB.  I couldn't find one on the cabinet.  Is there another one?
Jeff
Kevin Mullins
    • Me on Myspace
« Reply #5 on: September 22, 2009, 02:05:33 pm »
I don't know what your cabinet may have in it...... most people refer to a volume pot and they are just talking about the cabinet pot and don't realize there is even one on the pcb.
All it takes is a quick look to follow speaker wiring and see if it leads to a cabinet pot or not.
Usually right inside the coin door area or mounted to the cabinet wall somewhere reachable.
(if there is one at all)
jeff412
« Reply #6 on: September 22, 2009, 04:52:59 pm »
There is a spot for a volume control, but there isn't one.  Does this game have a sound board or is it all in the chips?
Jeff
Kevin Mullins
    • Me on Myspace
« Reply #7 on: September 22, 2009, 05:39:50 pm »
Are there wires just hanging there ?
There's no other sound board for that particular game, it's all onboard.
jeff412
« Reply #8 on: September 22, 2009, 07:21:40 pm »
Nope.  No disconnected wires anywhere.
Jeff
jeff412
« Reply #9 on: September 22, 2009, 07:24:28 pm »
1.  Does the cabinet volume pot connect in series with the speaker wires or is there a control wire that connects the pot to the board?
2.  Where would it connect?
3.  Anyone know where I can get the schematics for this game?
Jeff
jeff412
« Reply #10 on: October 02, 2009, 12:27:03 pm »
After doing a lot of research I found that Capcom CPS-1 machines were originally designed for the Z80A processor(It's even silk screened for it)  and built with the Z80 to save money.  Evidently, this cheaper processor has a higher failure rate.  Even though the sound test showed the processor passed, I changed it anyway.  I now have all sounds working.  Just thought I'd update this post in case anyone else has this problem.
Jeff
Kevin Mullins
    • Me on Myspace
« Reply #11 on: October 02, 2009, 03:02:38 pm »
I never would have even thought about something like that.
(mental note taken)
jeff412
« Reply #12 on: October 02, 2009, 03:54:29 pm »
Here's a link to some really good troubleshooting information on the Capcom CPS-1/CPS-2 machines.
http://newlifegames.net/nlg/index.php?topic=155.0
Jeff
« Last Edit: October 02, 2009, 03:57:20 pm by jeff412 »
SirPeale
  • Green Mountain Man
« Reply #13 on: October 02, 2009, 04:58:09 pm »
Noted!
