Author Topic: Need link to download latest MalaGamelist  (Read 3195 times)
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« on: September 19, 2009, 11:08:31 am »
There is a link on the forums to download mala 1.6 but just the exe itself.
Does anyone have a link to download the full zip with all the other files?
Apparently MalaGamelist 1.0.5 does not like the mala.mle file created by Mala 1.6 when you confiure OtherEmu and when I start MalaGamelist it I get an error:
"error loading emulator file".
"The Manuel"
Henrik68000
  • Last login:December 12, 2010, 01:54:23 pm
Re: Need link to download latest MalaGamelist
« Reply #1 on: September 19, 2009, 02:01:15 pm »
Im likewise very concerned  if the new versin 1.6 will accept my big seup with lists, layouts and all the stuff. Its taken more than 1 year to put this all together for me.
Henrik
TheManuel
« Reply #2 on: September 19, 2009, 02:04:05 pm »
That would be a pain if you had to re-do it all over again.
In fact, so far, I've seen very little reason to go with 1.6.
I'll probably just downgrade back to 1.0.5 to avoid all these issue I'm having.
"The Manuel"
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
« Reply #3 on: September 20, 2009, 04:08:22 am »
heres the latest or use romlister
TheManuel
« Reply #4 on: September 20, 2009, 09:05:21 am »
Thanks, dungbeetle.
It appears the link to the file is broken, though.
Could I bother you to post the whole suite including the other auxiliary files when and if you update the zip file?
"The Manuel"
dungbeetle46
TheManuel
« Reply #6 on: September 20, 2009, 09:37:40 am »
Thanks a lot.
That was fast.
You're the man.
I'll try later today on my arcade machine and see how it goes.
"The Manuel"
TheManuel
« Reply #7 on: September 21, 2009, 08:52:36 am »
That did the trick.
It was merely a case of backwards incompatibility between the MaLa 1.6 and the old MalaGamelist.
Now I have everything running smoothly with the new MaLa except for that crash when scanning for games in my OtherEmu folder.
"The Manuel"
NelsonPJ
  • Last login:June 17, 2020, 06:50:27 am
« Reply #8 on: September 21, 2009, 04:37:48 pm »
Thanks also for these files - I didn't even realize these were updated!
