Author Topic: K7000 after capkit  (Read 3668 times)
Cisek
  • Last login:May 19, 2023, 07:35:14 am
K7000 after capkit
« on: September 19, 2009, 08:31:06 am »
Hi
I just made capkit for K7000. The colours are much better, however I still have problems:
1. Green jail bars.
2. The image at the very bottom seems to squeezed.
3. (The worst) vertical position pot doesn't work at all and image is a little of center.
I would like to resolve especially the last problem.
SirPeale
  • Green Mountain Man
Re: K7000 after capkit
« Reply #1 on: September 19, 2009, 12:06:02 pm »
Pics!
Cisek
« Reply #2 on: September 19, 2009, 03:58:37 pm »
Green jail bars was bad expression, this looks more like green horizontal lines.
I couldn't get all effects on pictures, so I made videos.
This is how it looks, when there is nothing connected to the monitor.
[youtube]http://www.youtube.com/watch?v=yTZx8sISlRE[/youtube]
And here with MK2 (when in a game the lines aren't so visible, but still got the shifted picture problem):
[youtube]http://www.youtube.com/watch?v=rkKUAeYCx7k[/youtube]
SirPeale
« Reply #3 on: September 19, 2009, 06:46:36 pm »
The only real problem I note is your brightness is up too high causing those retrace lines.  Turn down the screen control slightly on your flyback.
I don't see the shifted picture. I can see it's not up to the top of the tube, but if you do that you'll start cutting things off @ the corners.
Cisek
« Reply #4 on: September 19, 2009, 07:32:51 pm »
Turning down the screen control helped a lot, thanks.
I don't think that centering the picture has to do anything with loss of the pixels in corners. I resoldered that v-pos pot and it still doesn't work   :-\
I also noticed, that when I extend the picture vertically, the upper lines seems to be wider. Can it be linearity problem?
« Last Edit: September 19, 2009, 07:43:45 pm by Cisek »
SirPeale
« Reply #5 on: September 19, 2009, 07:51:40 pm »
Oh, now I get it; adjust the 50/60Hz pot, that should fix things.
Cisek
« Reply #6 on: September 19, 2009, 09:21:00 pm »
It fixed the bottom that was squeezed, however the upper part still have bad linearity.
Cisek
« Reply #7 on: September 20, 2009, 12:13:58 pm »
The monitor problems are almost over. Everything fixed, except the vertical position. I dunno how can I center the image. Common guys, I know you can help.
Kevin Mullins
    • Me on Myspace
« Reply #8 on: September 20, 2009, 12:51:00 pm »
I have one right now with the same vertical shift problem. (not quite enough UP movement)
IF .... I decide to look into it I'll let you know.
(it's adjustable enough in other ways to not really bother with)
Cisek
« Reply #9 on: September 20, 2009, 02:21:03 pm »
That's great, i'll wait than.
Cisek
« Reply #10 on: September 21, 2009, 06:42:13 am »
Ok, so I finally spotted that one of the v-pos pot leg is broken. How to fix that?
SirPeale
« Reply #11 on: September 21, 2009, 07:33:33 am »
Depending on the break you could solder a piece of wire to the ends to bridge the gap, or you could replace the pot.
Cisek
« Reply #12 on: September 21, 2009, 07:42:52 am »
Can I buy such a pot in regular electronic store?
SirPeale
« Reply #13 on: September 21, 2009, 07:45:53 am »
It depends on how much stuff one of those stores carries.  Radio Shack?  Doubtful.
You  might ask and see if someone has one they'll drop in a padded envelope for you.  Otherwise it'll cost you big in shipping.
Cisek
« Reply #14 on: September 22, 2009, 10:26:32 am »
I replaced the pot and it is working!
However I made a really big mistake with changing also the C51 capacitor (0.68 uf 35v) to 1uf. I just thought that i'll save some time later, but I was wrong. With new capacitor I can't get enough height and the upper lines are squeezed. Now the problem is that I can't put the old cap again, because accidentally I broke one of its leg, so I must buy a new one. Do you know where can I get it from?
Cisek
« Reply #15 on: September 23, 2009, 08:02:42 am »
Can i replace C51 tantalum cap (0.68 uf 35 v) with the semi tantalum cap?
Cisek
« Reply #16 on: September 23, 2009, 05:12:02 pm »
Replaced the cap and... finally! Everything works perfect, thanks to you guys!
I have final question with 50/60 pot. If I adjust it to 60 hz, than games like mortal kombat are cut off at the bottom (it runs 53 hz) and if I adjust this pot to 53 hz, than when in 60 hz resolution, there is a squeeze at the upper lines. Is there possibility to adjust it, that 50 and 60 hz resolutions will display properly? It would be great as I use a mame cabinet with soft15khz and I change games and resolutions a lot.
