Author Topic: What games use 8-buttons? Do I need 8 per player?  (Read 1905 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
« on: July 14, 2003, 12:16:06 am »
Still doing research for my cabinet...
How many buttons do I need per player?
My two MAIN games are Marvel vs Capcom and Metal Slug.
Marvel vs Capcom uses 6 buttons.
Metal Slug uses 3 (but other Neo Geo games use 4).
So, should I have 7 buttons per player?  3 on a top row, and 4 on the bottom row (to support Neo Geo style).
Do any games use 8 buttons per player?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:What games use 8-buttons? Do I need 8 per player?
« Reply #1 on: July 14, 2003, 12:32:51 am »
Hardly anything uses that many buttons.
crashdmj
  • Last login:August 26, 2003, 08:55:42 pm
  • Hulk smash!
    • Best webpage in the Universe!!
« Reply #2 on: July 14, 2003, 12:56:58 am »
7 buttons should suffice, unless you plan numerous consoles (newer ones)! Good luck.
Derek
RedSquirrel
  • Last login:September 18, 2003, 12:07:55 pm
« Reply #3 on: July 14, 2003, 03:34:19 am »
Derek
Yeah remember if your doing 7 buttons, make the 7th (the extra neo geo one) a duplicate of say one of the top row buttons ie
 123
 456
3
This way it actually only uses 6 inputs.
outcast_p
  • Last login:July 10, 2003, 03:50:13 am
« Reply #4 on: July 14, 2003, 04:50:10 am »
Here is a visio template if your intersted in the 7button layout.
http://outcast.darkscape.net/7button.vsd
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #5 on: July 14, 2003, 07:53:55 am »
I'm using 8 - for ePSXe. Otherwise, what the squirrel said.
All Your Base Are Belong To Us!
Unkis17
  • Last login:March 24, 2017, 12:03:37 am
  • I'd keep on building if i had the space
« Reply #6 on: July 14, 2003, 10:12:48 am »
I use all 8, but only 7 to play.  the P1 S8 is a dedicated Pause button and P2 S8 is my middle button in a 3 button layout for my mouse (missile commnad layout).
My buttons are laid out as such:
 123  (All Blue)
7456  (Neo Geo Colors)
You can use a Controller.ini file to make the Neo Geo buttons take over when playing NG games.  then it will look like this
 XXX  (not used durning play)
1234 (In order of neo geo colors too!)
You have to use the switch -crtl when using it, but i haven't figured out how you would do this from a FE, say MameWah.  Does anyone know this one?
Xochi
  • Last login:June 03, 2005, 01:52:17 pm
« Reply #7 on: July 14, 2003, 02:18:33 pm »
If you ever decide to use a PSX emulator with your cab you will want 8 buttons.
sofakng
« Reply #8 on: July 14, 2003, 03:13:39 pm »
D'oh.  I had forgotten all about PSX emultion.  I definitely want to do that.
Looks like 8 buttons for me after all...
Thanks for all the suggestions though!
RedSquirrel
« Reply #9 on: July 14, 2003, 05:41:50 pm »
What is the quality of Playstation emulation now anyway?
night
  • Last login:January 09, 2018, 02:08:19 pm
« Reply #10 on: July 14, 2003, 10:38:12 pm »
i think 8 buttons is cluttered. im sticking with 6, and if i wanna play newer [console] stuff, i'll buy a usb adapter and use the actual pad.
IceCold
  • Last login:March 22, 2010, 05:11:22 pm
    • My MAME cabinet webpage
« Reply #11 on: July 15, 2003, 05:08:04 pm »
I haven't done it in awhile, but when I tried it around a year or two ago, it seemed pretty much perfect.  I would assume it's pretty much perfect now.
RedSquirrel
« Reply #12 on: July 15, 2003, 06:04:32 pm »
Yeah I doubt Ill do Playstation emu in my cab, I don't see the point really when I could use my actual PSX in the cab, plus you could wire a 7th/8th button up to somewhere else (ie a coin button) for the L2 / R2 buttons as they are not used much.
AlanS17
    • AlanS17
« Reply #13 on: July 15, 2003, 06:06:44 pm »
I just downloaded epsxe the other night to try it out. It works pretty darn well - even with newer games.
