Author Topic: Dynamo Hs-2 Cut Corner control panel measurements  (Read 3591 times)
xmitochondriax
  • Last login:May 22, 2010, 06:07:49 pm
« on: September 05, 2009, 04:26:40 pm »
I've been reading and googling for an hour or so and I can't find measurements on a cut corner control panel.
I'm trying to find the top width, bottom width, depth, height at the back, and height at the front. I can do the math to figure out the length of the cut corners, but if you want to post the exact measurements, that'd be rad too.
I'm going to build a couple mini-replica PS3 control panels with a SFIICE overlay. I've got the pads boards, buttons, and joys, so all I need now are the measurements so I can make the adjustments.
« Last Edit: September 05, 2009, 05:31:58 pm by xmitochondriax »
Dr Zero
  • Sunny Florida North
    • Drzero.org
Re: Dynamo Hs-2 Cut Corner control panel measurements
« Reply #1 on: September 05, 2009, 08:28:28 pm »
I have a cut corner control panel in the back of the truck with some stuff I picked up the other day, I will try to get some measurements off of it for you.
Might can get them tonight probably will be tomorrow I'm just now getting around to supper LOL
xmitochondriax
« Reply #2 on: September 06, 2009, 01:07:05 am »
rad!
Dr Zero
    • Drzero.org
« Reply #3 on: September 06, 2009, 06:49:40 pm »
OK here we go
The control panel is kinda odd shaped  in that its rounded on the front no definitive line there also there is a angled lip on the back that rest against the glass.
The measurements will be from the base of the angle.
ends are 5.5 inches
from back to the end of the angle 8.25
angle top 4.25
angle bottom 4.75
bottom end 3.25 3.5 with hinge
bottom 7 7.25 with hinge
center 8.25
about a inch radius across the front
width 23.75 widest point
width 17 3/8 narrowest point
Does this make any sense?
