Author Topic: 19" WG k4601 colors off-set  (Read 1791 times)
barfcark
  • Last login:August 31, 2009, 11:21:22 pm
« on: August 30, 2009, 11:52:45 pm »
I'm a noob to the scene. I got a Galaxian arcade a few months ago. I had to replace one of the monitor daughter boards(P297) and re-wire(P3??)(thanks Ken Layton). I'm glad to see/play something now, but the colors appear to be all off-set. I set the test pattern and took a picture. What's my next step? Convergence/Purity? I'm not familiar with this at all, but the manual that was with the arcade has some steps to follow... Any advice would be great. Thanks.
History: My brother-in-law kept this arcade outside a lot and then set it beside the road for trash pick-up. I scooped it up and hugged it all the way home.
Kevin Mullins
    • Me on Myspace
Re: 19" WG k4601 colors off-set
« Reply #1 on: August 30, 2009, 11:59:10 pm »
Yup, looks like the convergence rings have moved a bit.
Everything appears to be nice and straight though, so should be an easy adjustment.
Since it's only off in one direction, I would moved the rings in pairs NOT individually.
But then again...... all depends on what it does when you move them.
barfcark
« Reply #2 on: August 31, 2009, 01:06:00 pm »
So just break the adhesive "lock" on the ring and turn it? I have three sets of two rings...
Thanks.
EDIT: Adjusted rings and BOOYAH!
« Last Edit: August 31, 2009, 10:40:38 pm by barfcark »
Kevin Mullins
    • Me on Myspace
« Reply #3 on: September 01, 2009, 10:38:52 am »
