Author Topic: how do i connect a dotronix monitor  (Read 876 times)
pro_ccna
  • Newbie
  • Last login:September 01, 2009, 08:27:07 pm
« on: August 30, 2009, 09:39:30 pm »
Ok here is what i have and what i want to do..I have a dotronix 25in monitor with a 9pin vga connection also switchable to rgb..I have a nividia gforce 5500 video card that i tried to connect the monitor but just got a garbage image.The cable that i was useing is a 9pin to a 15pin.I tried to use soft 15 but not sure what to change.I read that these monitors need to run at 15khz,,correct me if im wrong.
The goal is to use this monitor with my pc for a gameing system..
so how can i connect this monitor?I know it can be done.
