Author Topic: Change monitor to vertical?  (Read 2747 times)
endrien
  • Last login:August 08, 2010, 08:33:36 pm
« on: August 29, 2009, 07:38:36 pm »
I'd like to do this, How can I?
if it matters my monitor is a Orion 2012/2022.
I don't mean turn the monitor either.
SirPeale
  • Green Mountain Man
Re: Change monitor to vertical?
« Reply #1 on: August 29, 2009, 08:10:28 pm »
If you don't mean by rotating the entire monitor, what /do/ you mean?
endrien
« Reply #2 on: August 29, 2009, 08:24:52 pm »
have it so games play vertical. Though I guess this would be controlled by the game itself, so if I bought a 48 in 1 that was vertical it would change itself.
mini77
  • Last login:September 16, 2009, 06:29:09 am
« Reply #3 on: August 30, 2009, 02:33:21 am »
No, you'd have to physically rotate the monitor 90 degrees.
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #4 on: September 01, 2009, 06:52:25 pm »
So ok, I have been biting my tongue... but there is a way.
Depending on the tube and yoke. If the yoke is not bonded, loosen the yoke clamp, break any seals such as silicone on the rubber wedges.
Now rotate the yoke 90 degrees.
Adjsut the vertical and horizontal size... butv expect that when you adjust the horizonatl size for proper proportions, that you will have black on both the left and right sides.
Probably not the best solution as when you switch back to Horizontal games... the game is not oriented right.
Not for an amateur who worries about high voltage and such, but not all that hard, it takes me less tahn a couple of minutes.
Good luck
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Jack Burton
« Reply #5 on: September 01, 2009, 08:12:21 pm »
Rick, does this change the orientation that the electron guns draw on screen as well?  So that it draws up and down across the surface of a horizontal screen?
SailorSat
  • Last login:February 07, 2026, 07:38:58 pm
    • For Amusement Only e.V.
« Reply #6 on: September 03, 2009, 04:24:35 pm »
Most likely will work but turn down screensize to minimum before you try that.
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
