Author Topic: Philips tv tube question  (Read 2254 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: August 29, 2009, 05:22:05 pm »
Can I use the tube off a 20s240c122 20 inch to replace the tube in my 19 inch WG?
SirPeale
  • Green Mountain Man
Re: Philips tv tube question
« Reply #1 on: August 29, 2009, 08:03:45 pm »
no.
iscariot
« Reply #2 on: August 31, 2009, 02:44:03 pm »
Wrong number of pins?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #3 on: August 31, 2009, 05:10:07 pm »
spacing of mounting ears will be dfferent .....
if the pin out is compatable , and ur willing ( have room)  to modify
the mount,  it can work.
iscariot
« Reply #4 on: September 01, 2009, 11:38:00 am »
Mounting ears is not an issue here.  I've got no problem adapting that part.
SirPeale
« Reply #5 on: September 01, 2009, 01:08:24 pm »
You'll also have to move the yoke over, and it won't fit the new tube.
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 01:57:20 am
« Reply #6 on: September 02, 2009, 08:47:09 am »
I've breathed new life into a 19" arcade monitor chassis (Nanao, not a WG) by connecting it to a 20" TV tube. It can work, but the yoke characteristics of the new tube have to closely match the original's otherwise you are cactus. As Peale pointed out, yoke swapping between different sized tubes is probably not going to work.
