Author Topic: aaaagh I'm tired of this flyback  (Read 7077 times)
  • Last login:October 19, 2022, 12:01:54 pm
« on: August 28, 2009, 08:32:28 pm »
So... monitor in Revenge From Mars, flyback going fast.  Not one of the originals, this one is a WG 72xx.  I'm not all that good at narrowing down the specific model beyond that, it seems.  I ordered a replacement flyback but the thing is 25% larger than the original.  Same pinout, it appears, but doesn't fit in the spot on the board.
The flyback I just pulled has a sticker that says WG 1723201.  It also has CM-27-18 9503 on it.  Googling on those numbers isn't getting me anywhere.
The replacement that is too large looks the same but has only a sticker that says 053X064001.  I'm guessing I ended up with a flyback for a 25".
Help me find the right replacement?  Somehow this is stumping me.
[youtube]http://www.youtube.com/watch?v=q1Ugqh471IE[/youtube]
Kevin Mullins
    • Me on Myspace
Re: aaaagh I'm tired of this flyback
« Reply #1 on: August 28, 2009, 11:57:50 pm »
A 13" or 19" chassis I presume ?
Does that deflection board have a "P819" on it somewhere ?
WG K7203
Try Googling 2ATFT1415-002  ;)
That WG 1723201 number would be a serial number.... but pretty useless actually.
That 053X0641-001 is indeed for a 25" K7200.
« Reply #2 on: August 29, 2009, 10:11:42 am »
19", currently in a pin2k.  I don't see a P819, I see a P757-D.
Done, thanks... too bad I'll probably never have a 25" raster.  That was a quick $40 down the drain.   :P
Kevin Mullins
    • Me on Myspace
« Reply #3 on: August 29, 2009, 12:52:24 pm »
The P757 is for a straight up 19K7200.... also used on a 13K7201 (Type 13) monitor.
http://www.wgec.com/bom/P757.pdf
Wells Gardner part number for that flyback is 053X0641-001.
Been there done that.
Bought a $75.00 flyback I ended up not needing and of course it's for a particular chassis I will most likely never need one for ever again.
« Last Edit: August 29, 2009, 03:42:19 pm by Kevin Mullins »
« Reply #4 on: August 29, 2009, 03:34:42 pm »
Yes!  There's a sticker in the cabinet that fell off with that part number on it.  I wasn't sure where in the game it came from.  Now I know.  :)  I owe you a beer, my friend.
Found one here.
Kevin Mullins
    • Me on Myspace
« Reply #5 on: August 29, 2009, 03:43:03 pm »
But isn't that the same part number as the flyback you got the first time around ?
(I assumed you missed one digit in your original post)
« Last Edit: August 29, 2009, 03:47:04 pm by Kevin Mullins »
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #6 on: August 29, 2009, 08:05:29 pm »
Not necessarily down the drain, I'm sure you can sell it since it hasn't been used.
« Reply #7 on: August 30, 2009, 03:09:16 pm »
Nope, didn't miss a number, just verified.  That's what the bigger one says.
« Reply #8 on: September 03, 2009, 08:18:19 pm »
 :banghead: :banghead: :banghead:
So, the new one arrived today... and it's the same flyback as the first replacement.  Too large.
The two replacements are the same size and yet have two different part number stickers on them.  One of them is an identical number to the original but the part is clearly about 25% larger.
I will get some pics when I'm less pissed off.  Now I have bought two of the same incorrect replacement, the stickers clearly aren't right, aaaaaaaaaaaaaargh.
sarge
  • Last login:April 27, 2015, 01:42:54 pm
« Reply #9 on: September 03, 2009, 10:17:40 pm »
You can try happ part # 49-0812-00.  Are you sure what model monitor you have?  And just to avoid any confusion wells never made a 25" 7200 series monitor.
Kevin Mullins
    • Me on Myspace
« Reply #10 on: September 03, 2009, 10:35:49 pm »
That's kinda what I was afraid of......... that the first one just had a typo on the new part number sticker. (missing one digit)
I think I have a couple P757-D chassis laying around I can look at.
Also have a box of new flybacks I aquired, so I'll do some comparison. (I know there's a 641 in there)
« Reply #11 on: September 04, 2009, 08:13:25 am »
The dumb part is the sticker on the original clearly says 053X0641-001.  So it's possible it is the original that is mismarked.  I can't seem to get a clear pic of that because it's so small and faded.
Kevin Mullins
    • Me on Myspace
« Reply #12 on: September 04, 2009, 11:26:34 am »
Even the parts list for that P757 chassis calls for the 053X0641-001.
So something wonky is going on here.
What's the neckboard number out of curiosity ?  (Pxxx)
« Reply #13 on: September 04, 2009, 01:38:46 pm »
Just so folks know I'm not crazy...
« Reply #14 on: September 04, 2009, 01:53:00 pm »
The original flyback is on the left... two replacements on the right.
The chassis.
Kevin Mullins
    • Me on Myspace
« Reply #15 on: September 04, 2009, 02:20:16 pm »
I just looked at two P757-D chassis which are originally from a 13K7201, same chassis as yours though and I also checked the extra flyback I had in a box which is not new but a pull from another 757-D....... all match your original, all marked with identical stickers that clearly say 053X0641-001 by Meritron. And they are fairly smallish compared to most other flybacks.
Does the footprint of the replacement flybacks match your chassis ?
I've seen a couple new flybacks for other chassis not match the heatsink mounting screw/tab setup, but matched the the chassis pinout.
SirPeale
« Reply #16 on: September 04, 2009, 03:45:33 pm »
Do the pins on the fly match the holes on the chassis?  What gets in the way?
« Reply #17 on: September 04, 2009, 03:47:37 pm »
The pinout appears to match but the footprint isn't even close.  I can't get it into that spot because it would overlap the resistors around the edge of the dirt shadow.  The heat sink would be able to return to almost where it was but not quite - plus the heatsink was screwed to the original flyback where there is no threaded hole on the bigger ones.
Kevin Mullins
    • Me on Myspace
« Reply #18 on: September 04, 2009, 03:51:23 pm »
Starting to look like one of those "differences in manufacturers" issues.   :P
« Reply #19 on: September 04, 2009, 04:07:04 pm »
At this point I've spent $70 on flybacks.  I'm not all that anxious to buy another.  Maybe at this point I should just buy a full working chassis.
Kevin Mullins
    • Me on Myspace
« Reply #20 on: September 04, 2009, 04:15:48 pm »
Ah com'on now....... there can't be but a couple thousand more out there to try.  ;D
Just curious.... what's the symptoms on the old one ?
(deeming a bad flyback)
I could pull and test one of these I have here.
I have one fully working monitor, two unknown flybacks I would have to test first.
« Last Edit: September 04, 2009, 06:27:02 pm by Kevin Mullins »
SirPeale
« Reply #21 on: September 04, 2009, 06:15:02 pm »
Well, that sucks.  Good news is you can likely sell those flybacks - bad news is you have to find out what monitor they go to AND find a replacement for the one you have.
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #22 on: September 04, 2009, 07:31:03 pm »
seems to me you must be close to ordering our LCD retro Kit. If I have not been clear, it does the original Pin2k without ant converter boards....
Ready for Nu-core if you so desire.
good Luck
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
« Reply #23 on: September 04, 2009, 07:48:24 pm »
Deteriorating focus, mostly.  It would start fine, then after a few minutes the focus would slowly go away.  Eventually it started happening faster and faster.  When I checked the flyback I noticed a hairline crack in the housing just above the focus knob.  The screen control was already turned up high enough that black level was grey, too, making the whole screen visible on the playfield glass.
Awesome... if you get to it in your normal course, cool, if not, I'll keep poking around.  Thanks for the offer and all the advice.
rickn, thanks for the offer, but $360 is out of my current price range, especially for a 19" LCD.
