Author Topic: Anyone got a good plan for a cabinet to house a 36" crt?  (Read 2833 times)
Drakin
  • Last login:December 10, 2022, 12:51:42 pm
« on: August 27, 2009, 10:30:13 am »
Looking for plans and or advice on what cabinet design I should go with to house a 36" crt monitor.
Thanks for any input.
Drakin
severdhed
  • RIP Dinosaur Hippo
Re: Anyone got a good plan for a cabinet to house a 36" crt?
« Reply #1 on: August 27, 2009, 10:39:44 am »
we have a 36" gateway destination monitor on our cabinet at work.  i use the term cabinet loosely though, because we never really finished it.  for something that large, you should definitely go with a showcase style cabinet, where the control panel is on a separate pedistal that can be back away from the monitor.  our's is two separate pieces so we can move the control panel up against the monitor when not in use, then when we want to play, we pull it back so that there is at least a foot between the back of the panel and the monitor.
i dont have any plans, we were kinda just making it up as we go.  i remember seeing someone had dynamo showcase cab plans here somewhere, but they would have to be modified because they were for a smaller monitor i think.
Drakin
« Reply #2 on: August 27, 2009, 10:45:08 am »
Thanks, I'll do a search and see what I can dig up.
  • Last login:Today at 06:40:27 am
« Reply #3 on: August 27, 2009, 11:12:38 am »
Shouldn't you be asking if anyone has a good plan for a house for a cabinet with a 36" CRT?   ;D
If you are going that big then a showcase cab is probably the way to go - anything else and you won't be able to follow the action standing so close...   :cheers:
Drakin
« Reply #4 on: August 27, 2009, 11:53:06 am »
LOL...yea not shure if the house will house the cab...
RyoriNoTetsujin
  • Last login:March 23, 2024, 03:55:45 pm
« Reply #5 on: August 27, 2009, 03:54:20 pm »
LOL.  As someone with a 31" Desti in his cab (which had to be scratch-designed around the monitor: quarterheaven.livejournal.com) I cannot recommend a showcase style cab enough!  ;D
In the end, a showcase style will save you massive amounts of pain and trouble, not to mention it's a really easy style to scale up or down depending on your needs.
Edit: In other words, DON'T try to do what I did.
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
« Reply #6 on: August 27, 2009, 06:50:57 pm »
http://www.ricweb.com/webyep-system/daten/5-48-im-Bild1-neu-e-8592.jpg
Something like this, only not light guns and instead a podium type control panel.  SEems to be the way to go.  You could also thusly seperate it to make it more transportable.
zelony
  • Last login:November 16, 2019, 04:00:12 pm
    • Green Chavez Law Firm
« Reply #7 on: August 27, 2009, 07:12:45 pm »
Go buy yourself a showcase cab.  This is what I did and then put a 36" SVGA monitor in it.  Here is a picture of what I bought.  The picture is from the KLOV website.
Buy the nicest condition cab you can afford, it will make the conversion to MAME easier.
Dr Zero
  • Sunny Florida North
    • Drzero.org
« Reply #8 on: August 27, 2009, 07:27:05 pm »
The showcase cabs are pretty cool lots of room and modular, I have this style of Dynamo showcase
D10
  • Last login:April 08, 2022, 12:44:44 pm
  • Pull my finger
« Reply #9 on: August 27, 2009, 09:46:16 pm »
There are some drawings for a 34" Dynamo cab on Jakobuds site. Maybe you can modify it to fit your needs.
http://www.jakobud.com/cabinetPlans.php
« Reply #10 on: August 28, 2009, 08:30:06 am »
Well said.  I tested a 36" Destination for a while trying to make it work.  I really didn't want a showcase just due to the size.  But you really have to be standing back from a 36" tube to play comfortably.
