Author Topic: Komo kmp=2935vs neck board  (Read 2310 times)
RichSorr
  • Last login:August 29, 2015, 07:27:00 pm
« on: August 18, 2009, 08:51:19 pm »
I have one of these monitors in one of my locations and the neck board is all burnt up. The trim pots and surrounding resistors are burnt to hell and most of the pots have fallen apart.  I have the same exact monitor buried in my garage, and if I remember correctly, i was working fine 2 years ago when I pulled it out of a machine. Same areas look like they were beginning to burn up...here is a pic
The monitor I have on location works fine, the colors are just out of whack, and I can't seem to find a schem so I can get the proper pots and resistors to fix this. Can anyone out there help me out with getting schematics for this thing?
Much appreciated. thanks
Rich
RichSorr
Re: Komo kmp=2935vs neck board
« Reply #1 on: August 21, 2009, 09:36:03 pm »
bump.
If I wanted to get some pots from mouser what would be a good replacement?
grantspain
« Reply #2 on: August 22, 2009, 04:47:28 am »
do you have the pot values,if you look on the pot itself there should be a number like 101
RichSorr
« Reply #3 on: August 24, 2009, 08:06:58 pm »
no dice. pots don't have any markings on them at all.
grantspain
« Reply #4 on: August 26, 2009, 02:22:47 am »
you may need to desolder one as some pots are marked underneath
RichSorr
« Reply #5 on: September 07, 2009, 09:10:49 pm »
kind of forgot about this. two pots are marked 12 and the other three are marked 14
grantspain
« Reply #6 on: September 07, 2009, 10:48:31 pm »
i think 12=100ohm and 14=1kohm
could do with a second opinion though
RichSorr
« Reply #7 on: September 12, 2009, 10:19:38 pm »
so I figured out what resistors I needed. Could anyone point me in the right direction for the correct pots? link maybe, so many damn choices on mouser. thanks
edhiatt
  • Newbie
  • Last login:January 04, 2012, 03:14:39 pm
« Reply #8 on: January 03, 2012, 04:30:39 pm »
Do you still have komo kmp-2935v if so how much email edhyttozzy@yahoo.com
