Author Topic: Wiring Tact Switches to Xbox 360 Triggers  (Read 3478 times)
foreverlastd
  • Last login:September 12, 2009, 02:15:13 pm
« on: August 17, 2009, 12:28:39 am »
Hi there, I'm building a custom made Xbox 360 arcade stick and I'm hung up on wiring up the triggers. I've looked around and couldn't find the answer I needed. I just need to see how the tact switches need wired and where (if needed) the resistors are attached. I attached an image to the topic. If you could just draw the connections (and resistors).
-Mike
  • Last login:July 09, 2025, 01:34:12 pm
Re: Wiring Tact Switches to Xbox 360 Triggers
« Reply #1 on: August 17, 2009, 09:08:30 am »
What controller are you using?  (MadCatz, Wireless, Wired Official, etc).
foreverlastd
« Reply #2 on: August 17, 2009, 10:54:20 am »
It's the official wireless controller.
« Reply #3 on: August 17, 2009, 11:23:33 am »
Is it the older, non-common ground PCB, or the newer common ground PCB?
foreverlastd
« Reply #4 on: August 17, 2009, 06:22:33 pm »
I can't look at the physical controller at the moment (as it's 130miles away) but I know it's the same design as this one ( http://www.instructables.com/files/deriv/FLR/BM3T/FIN3ZDRY/FLRBM3TFIN3ZDRY.MEDIUM.jpg ) .
« Last Edit: August 18, 2009, 04:50:30 pm by foreverlastd »
foreverlastd
« Reply #5 on: August 19, 2009, 06:29:09 pm »
*Bump*
