Author Topic: Weird mala problem  (Read 1377 times)
technocop
  • Last login:November 03, 2009, 04:55:45 pm
Weird mala problem
« on: August 16, 2009, 07:16:14 am »
Occasionally, after starting up mala, I get a weird problem. Mala seems to lock up for a few seconds, then runs extremely slowly. When I drop back to windows, everything seems to be running slowly there too. Windows drag around the screen REALLY slowly, and the start menu takes a while to fade in and out when you click on it.
A reboot ALWAYS fixes the problem, and mala works first time.
I'm running mala on top of mameuifx 0.132 on xp sp3. The machine is an old P4 with an arcadeVGA, but still plenty adequate for mame.
Anyone seen anything like this?
GaryMcT
  • Last login:September 24, 2014, 11:19:27 am
    • GaryMcT's arcade blog
Re: Weird mala problem
« Reply #1 on: August 16, 2009, 12:21:38 pm »
Sounds like a graphics card driver problem. The driver dies and Windows falss back to the default VGA driver. I'd try updating to the latest driver for your graphics card and see if that helps.
My blog on learning how to develop FPGA versions of arcade boards: http://garymct.blogspot.com
technocop
« Reply #2 on: August 16, 2009, 12:55:07 pm »
at first I thought it was a gfx driver too, but it only ever happens when I load mala
I don't have the option of getting the latest drivers, as I'm using the arcadeVGA
GaryMcT
« Reply #3 on: August 16, 2009, 01:11:26 pm »
The driver definitely doesn't like something that MaLa is doing.
technocop
« Reply #4 on: August 16, 2009, 02:42:34 pm »
well.....i'm not sure it's the graphics driver. I've seen windows drop to its default driver before, and it doesn't look like this.
I was hoping someone else might have experienced it. ???
It doesn't happen if I use the mameuifx front end...but that's not really suitable for cab use.
might end up trying out some different front-ends.....
GaryMcT
« Reply #5 on: August 16, 2009, 02:45:52 pm »
It may not be dropping back to VGA, but the driver is likely in a bad state due to something MaLa is doing.
You are right, I'd try a different front end.  I gave up on MaLa personally due to the fact that user input is so sluggish.
