Author Topic: 12 core 16/0.2mm (20AWG) cable - CP wiring (UK-Int Shipping)  (Read 2013 times)
Franco B
« on: August 11, 2009, 05:16:00 am »
I have some 12 core 16/0.2mm (20AWG) cable for sale.
Number of Cores 12
CSA 0.5mm²
Voltage Rating 440Vac
Current Rating 2.5A
Insulation Material PVC
Outside Diameter 9.9mm
Screened No
Core Strands 16/0.2mm (20AWG)
I had to order 25m of it but I will only need 5m max. It should be the perfect cable for uber neat CP wiring  :)
The 12 cores could be used for 6 buttons per player, 4 joystick micros (8/4 way) plus ground leaving one extra wire which could be a seventh button or start etc button.
Price will be £1.80/$3 per meter plus actual shipping.
Franco B
Re: 12 core 16/0.2mm (20AWG) cable - CP wiring (UK-Int Shipping)
« Reply #1 on: August 17, 2009, 01:05:52 pm »
Bumpity :bump
It fits AMP pins a treat too.
« Reply #2 on: August 17, 2009, 01:09:09 pm »
Hey, did you pick up amp connectors for your Candy cab?
Who's your source on those?
Franco B
« Reply #3 on: August 17, 2009, 01:46:39 pm »
Sure did, for use with your DC hacks  ;)
I got them from Andy @ [Sega Shed].
You can get them from [Starcab] and I have also been told that you can get samples from [Tyco], maybe enough to do your cab for free.
I had a quick look around for a US distributor for you but I didn't come up with much, probably due to not knowing part numbers etc. I know on my Naomi's they are type b AMP connectors (10 and 12 contacts) but that's it.
« Reply #4 on: August 17, 2009, 02:09:57 pm »
Yeah, I've got samples from Tyco in the past...   ;D  8)
I have the part numbers, but never could find a US distributor for them.
