Author Topic: Kman-Sweden - F.A.C.B.- Now with Neo-Geo hardware. Feb 2 - 2010.  (Read 46538 times)
Kman-Sweden
  • Up the Irons!
Re: Kman-Sweden - First arcade cab build. 95% done! Nov 28 - 2009.
« Reply #120 on: December 03, 2009, 01:17:30 am »
You did good work.  Only thing I would have done differently is used smaller and black colored marquee retainer, and used a bigger screen, but those can be upgrades for later!
Nice job, enjoy the games!
Point taken... They might look smaler if painted black... Cheers. :cheers:
Kman-Sweden
  • Up the Irons!
« Reply #121 on: December 03, 2009, 01:24:40 am »
Hey we're on page four here, and with almost 5500 views.. Nice!  ;D
Thanks for that y'all.
Here's a pic of the control panel in mid-wiring. I started off by wiring all the lights to the two LedWiz'es.
Then I grounded everything and when this picture was taken I had wired player ones buttons and was running out of wire... fast..
I had to change wire color a couple of times but I desided that I'd rather have this done then worry about wire-color.
Custom Cab logo in place. What do you guys think about it?
  • Last login:Yesterday at 02:34:47 pm
Re: Kman-Sweden - First arcade cab build. 96.5% done! Dec 3 - 2009.
« Reply #122 on: December 03, 2009, 03:57:39 am »
Custom Cab logo looks awesome!  :cheers: Button labels... not so much.  :laugh2:
Kman-Sweden
  • Up the Irons!
« Reply #123 on: December 04, 2009, 09:28:35 am »
rablack97
« Reply #124 on: December 04, 2009, 09:55:28 am »
Nice build   :notworthy:, not sure what you have access too where you live, but you might check in your local hardware store and look for metal sign stakes.  I know it sounds weird, but I found some that are perferct marquee retainers, they already have screw holes precut and are l-shaped, smaller and painted black.  Just cut the pointed end off to size and your good to go.  I'm going to the hardware store today, to pick one up, I'll post a pic for ya for a visual.
Here is my build, i'm gonna post some more updates tonight as well.
http://forum.arcadecontrols.com/index.php?topic=96162.0
Kman-Sweden
  • Up the Irons!
« Reply #125 on: December 04, 2009, 01:57:21 pm »
Sure! Post a pic for me. Thanks.  :cheers:
Kman-Sweden
  • Up the Irons!
« Reply #126 on: December 05, 2009, 06:23:14 am »
Here's an update for y'all..
This is my Keyboard hack for the service buttons. I started of ripping apart a USB keyboard and soldering some wires to a nice 26-pin connector.
You can read more about how I did it on my website. I broke the cable I made for the Keyboard hack so I had to make a new one.
So I just cut one end of a floppy cable and then cut the connector down to size from 32-pins to 26-pins. It worked out really nice.
Then I just crimped quick connectors to the ends of the cables and attached them to the switches.
Then I fastened the PCB inside the cab and started the work of powering the LED's. I just daisy chained both 5v and ground to all LED's.
My player 1 and Player 2 buttons aren't lightable to date but I daisy chained enough connectors so I can light them If I replace the buttons in the future.
"Let there be light!" I fastened the "Service Panel" with magnets so that it can be removed from the front. This is vital for the removal of the CP.
Here's some closeups of the buttons labeled. I printed out the labels in 4-5 different fonts and sizes and then used the diffuser in on of the buttons
to make a nice circle around the labels. Then I just cut them out and assembled the buttons again. Easy-peasy.
Closeup 2.
That puts me at 98% done I think. :D -Kman
« Last Edit: December 05, 2009, 05:12:39 pm by Kman-Sweden »
rablack97
Re: Kman-Sweden - First arcade cab build. 98% done! Dec 5 - 2009.
« Reply #127 on: December 05, 2009, 11:09:46 pm »
Here ya go, I stopped for a sec and took a few photos of the stake I was talking about.
They come with a sharp end for sticking in the ground, I just took the dremel and shave that off to size.
Kman-Sweden
  • Up the Irons!
« Reply #128 on: December 06, 2009, 02:37:17 am »
Thanks Rablack97.
I got a question about how my CP is attached to the Cab?
I drilled four holes and used "Wagon bolts"(?) and Wing nuts like this. Hope it helped.
Just ignore all the dust, Ok?  ;)
« Last Edit: December 06, 2009, 02:40:36 am by Kman-Sweden »
« Reply #129 on: December 06, 2009, 03:19:14 am »
Looking pretty good Kman, congrats.
Though, it's too bad you don't have illuminated P1 & P2 buttons to go with the rest of that panel...
Kman-Sweden
  • Up the Irons!
« Reply #130 on: December 06, 2009, 02:54:21 pm »
Thanks.  ;D
If you look close enough you can see I've made all the wiring for them to be iluminated also. just need to buy 'em.  ;)
Kman-Sweden
  • Up the Irons!
Re: Kman-Sweden - F.A.C.B. Kickplate and new marquee retainers Dec 8 - 2009.
« Reply #131 on: December 08, 2009, 04:39:28 pm »
Small (read easy) but noticeable update today. Kickplate installed.
I also changed the Marquee retainers to a smaller pair. I'm really pleased with this update..
« Last Edit: December 08, 2009, 04:41:54 pm by Kman-Sweden »
Kman-Sweden
  • Up the Irons!
Re: Kman-Sweden - F.A.C.B. Gun holsters. Dec 27 - 2009.
« Reply #132 on: December 27, 2009, 02:23:33 pm »
I had a pair of CD/DVD booklets (is that what they're called?) laying around my office/arcade. And suddenly it struck me.. Those would make great holsters for my ActLabs guns.
I ripped out the pages, cut the zipper away and then screwed them into place. Then I glued the open end shut making it like a triangular tube. A.k.a. a pair of holsters.
It took me about 10 minutes to do both. Here's two pictures of the result.
« Reply #133 on: December 27, 2009, 03:04:04 pm »
Looking great!  :cheers:
Kman-Sweden
  • Up the Irons!
« Reply #134 on: January 17, 2010, 12:01:04 pm »
Swedish 1-, 5- and 10-Krona coins.
I've bought two coin mech for Swedish coins. One for the 5-Krona and one for the 10-Krona coins.
However I've also placed an order for the BYOAC tokens and decided to modify the 10-Krona mech to accept larger coins.
The 10-Krona is 20mm (0.787401575 inch) and the 1-Krona is 25mm (0.984251969 inch)
My goal was to get it to accept the 1 Krona coin and at the same time make the tokens work..
The 5-Krona is to big (28mm, 1.1023622 inch) for the mech so I'll keep the 5-Krona mech as is.
Here's a simple picture to illustrate how I did it.
Hope it helps someone.
Re: Kman-Sweden - F.A.C.B.- Now takes BYOAC tokens. Jan 17 - 2010.
« Reply #135 on: January 17, 2010, 12:38:31 pm »
Nice job on the holsters.!
Kman-Sweden
  • Up the Irons!
« Reply #136 on: January 17, 2010, 01:15:07 pm »
They do the job.  :cheers:
painterinfo
  • Last login:August 09, 2010, 05:29:27 am
  • Arcade10
« Reply #137 on: January 18, 2010, 04:08:50 am »
Just read the entire thread, you have a slick machine there. You have me seriously thinking about a gun holster for mine now.
I could not help digging out my “Independence Day” video to get this screen capture.
Scripting Wizard
Kman-Sweden
  • Up the Irons!
« Reply #138 on: January 18, 2010, 04:40:13 am »
 ;D It's to help me figure out a nice CP overlay.
« Reply #139 on: January 18, 2010, 08:00:20 am »
I would do a "move strip" at the bottom of the overlay and leave the top to some nice graphics. This way you have all the info in one place and it'll look less cluttered.
painterinfo
  • Arcade10
« Reply #140 on: January 18, 2010, 08:13:49 am »
I like classic designs, but a design like that alien cockpit with stick-it notes printed onto the overlay is an idea at least.
I luckily have not had to think of a design for mine as I used stainless steel.
Maybe something 1950's ish or automotive for you to match the custom cab font.
Scripting Wizard
Kman-Sweden
  • Up the Irons!
« Reply #141 on: January 18, 2010, 11:39:29 am »
I'm have a plan to edit my frontend in a way that it explains the controls needed to choose emulator and select a game. The idea I have for the overlay is to "halo" the player buttons and mark them with player1 and player2. I'll "arrow" the joysticks with big 4way and small 8way arrows. Finally I'll point out/"halo" the flipper buttons and put in a designated "Launch ball" button on the front-right-angeled side of the CP.
In the begining, I actually had plans to do a checkered, yellow and black, taxicab theme. With bright yellow t-mold and a pair of orange turn indicator lights on top.
One day who knows?....  ;D
painterinfo
  • Arcade10
« Reply #142 on: January 19, 2010, 07:21:43 am »
How about something like this, a Blue FJ Concept, trackball over the front headlight.
I have the image in 2194 x 1446 res and Photoshop format if you want it.
Here is the original
http://www.blogcdn.com/www.autoblog.com/media/2006/12/holdenefijy_01.jpg
« Last Edit: January 19, 2010, 05:31:32 pm by painterinfo »
Scripting Wizard
Kman-Sweden
  • Up the Irons!
« Reply #143 on: January 19, 2010, 01:41:37 pm »
Thanks, I'll be sure to let you know if I need it.  :cheers:
Kman-Sweden
  • Up the Irons!
« Reply #144 on: January 19, 2010, 01:55:26 pm »
I don't know if you guys have noticed my 4-way / 8-way indicator LED's?
The joysticks change from 4- to 8-way by pulling and twisting and there's no way to know in what setting they are witout opening the CP.
I made two of these.
I wired two 12V LED's to a switch, one on the NO and the other on the NC. This way one is always on.
The white arm presses or releases the switch and thereby turns one LED on and the other LED off. Easy.
I drilled holes in the CP just above the joysticks but left the LED's flush with the MDF UNDER the overlay.
They'll shine through the overlay displaying numbers that are hidden below the final overlay.
Re: Kman-Sweden - F.A.C.B.- 4-way/8-way indicator LED's. Jan 19 - 2010.
« Reply #145 on: January 19, 2010, 04:20:20 pm »
I was wondering what those little lights were on your CP top.  Totally forgot to ask.
That's a great idea. I'm kinda doing the same for my CP switchbox, having LED indicators for what control input is active at a given time (PC or other).
Good stuff!  :applaud:
Silas (son of Silas)
« Reply #146 on: January 20, 2010, 05:57:58 am »
Nice idea with the LEDs. Bookmarked and officially 'stolen' for my cab.  ;)
My Project MAME clone
Who is Silas?
Kman-Sweden
  • Up the Irons!
« Reply #147 on: January 20, 2010, 07:45:51 am »
You're welcome.  ;)
lettuce
  • Make It So!
Re: Kman_Sweden - First arcade cab build. Updated 28-9-2009.
« Reply #148 on: January 20, 2010, 08:54:14 am »
Kman, how did you get that lightning effect in photoshop??
Bender
« Reply #149 on: January 20, 2010, 09:26:48 am »
I can feel the difference in the restrictor, but love your Idea anyway,  ummm more pretty lights
Kman-Sweden
  • Up the Irons!
« Reply #150 on: January 20, 2010, 11:04:43 am »
There's tons of guides out there. Have a look here ---> http://www.world-of-cha0s.hostrocket.com/lightningtutorial/tutorialmain.html
« Reply #151 on: January 20, 2010, 12:58:56 pm »
Cool idea with the indicator lights!
Kman-Sweden
  • Up the Irons!
« Reply #152 on: January 20, 2010, 01:16:18 pm »
thanks guys. I haven't seen it anywhere before. That always makes me happy.  ;D
Kman-Sweden
  • Up the Irons!
« Reply #153 on: January 27, 2010, 04:24:06 am »
Small update on the PC side.
I realized that my server is running with 2GB of RAM and the arcade with only 768Mb.
Did some quick redividing of RAM's and ended up with 1,5 GB's in the arcade cab and 1,2 in the server.
Also overclocked the P4 from 2,60 to 3.12 (+20%)  ;D Stable with temperature at approx 42C.
Re: Kman-Sweden - F.A.C.B.- More RAM and overclocked CPU. Jan 27 - 2010.
« Reply #154 on: January 27, 2010, 06:02:40 pm »
I must see more cab update pics!!!!!
Kman-Sweden
  • Up the Irons!
« Reply #155 on: January 28, 2010, 02:17:13 am »
Ha! Right back at you, Ond!  :cheers:
How bout this to prove me last post?
« Last Edit: January 28, 2010, 02:24:37 am by Kman-Sweden »
Kman-Sweden
  • Up the Irons!
Re: Kman-Sweden - F.A.C.B. - Now with Neo-Geo hardware. Feb 2 - 2010.
« Reply #156 on: February 02, 2010, 06:56:08 am »
So today I took my first step towards "real" arcade hardware.
I took a one-and-a-half hour drive to Stockholm yesterday. I went there to look at some bigger monitors.
The good new is that my cab can just fit a 29" tri-sync tube. ;D
The bad news is that the tubes don't come cheap.
Well anyhow, this is what I DID come home with!
1.) A 4-slot Neo-Geo MB
2.) A CGA/EGA/YUV to VGA converter that features CGA/EGA signal auto scan(15K,24K,31K) and YUV signal auto scan(480i,576i,720i,1080i,480p,576p,720p,1080p).
3.) A 15 Amp Power supply.
4.) A 100-in-1 MVS cartridge.
Here's everything hooked up for testing, as always on the floor.
Success! ;D
Game menu. Some really good games on this one.
Now I have to figure out a way to switch the controlls from the Ipac to the Jamma/Neo-Geo cables.
I think I have a old manual printer switch that might come in handy... Stay tuned.
/K-Man.
« Last Edit: February 02, 2010, 07:00:58 am by Kman-Sweden »
Re: Kman-Sweden - F.A.C.B.- Now with Neo-Geo hardware. Feb 2 - 2010.
« Reply #157 on: February 02, 2010, 08:52:19 pm »
Cool.  :cheers: So, that 4-slot is true JAMMA then, and not "NEO GEO-JAMMA"? Didn't they have any 1-slots btw, or do you plan on getting some of the games that aren't on the 100-in-1 cart? IIRC, it's mostly fighters, the Slug series, and a couple of hacked titles?
When you were in the shop, did you get to see the Panasonic tri-syncs showing games as well? I'm curious of the picture quality...
Kman-Sweden
  • Up the Irons!
« Reply #158 on: February 03, 2010, 05:44:54 am »
No the Neo-Geo and true Jamma has some diffrences. Jamma has the -5V and a Tilt switch that is missing from the Neo-Geo's 56 pin.
Then again Jamma is mono only while Neo-Geo is stereo. Neo-Geo has some "Select Up" and "Select Down" and Coin 3 & 4 that missing from the Jamma.
In all 7 out of 56 are in the wrong place. I dont really have to move any cables just re-label them. No problems.  ;D
They did have two 1-slot NG's left (I think), I got the last 4-slot (again, I think).
I might (probably will) buy more games in the future so I thought I'd better get the 4 slot so I don't have to open the cab all the time to change games.
The monitors where all on the shelfs and nothing was up and runing.
From one thing to another, are you going to get in on the JP deal for another EgretII? Do they come with a actual game aswell or is it only cab and cp?
Franco B
« Reply #159 on: February 03, 2010, 06:02:59 am »
Heh, I just wired up a MV-4F  like yours to a Jamma cab. I also installed the same CGA>VGA video converter as yours, I may have even bought the same Jamma PSU too  :lol
My converter has gone faulty though and I'm going to have to buy another one  :'(
Good work on the tri-sync. I bought myself a new 29" Sanwa PFX tri-sync for one of my cabs.
You won't need the video converter once you have your tri-sync will you?
Edit: Just for reference, all of the 1 slot MVS mobo's are Jamma compatible, its just the MV-2F, MV-4F and MV-6F (two, four and six slot mobos) that are not strictly Jamma compatible without an adapter or a little re-wiring.
« Last Edit: February 03, 2010, 06:29:47 am by Franco B »
