Author Topic: Wiring Joysticks  (Read 938 times)
Gromet
  • Last login:October 31, 2003, 10:11:45 am
Wiring Joysticks
« on: July 11, 2003, 10:23:07 am »
OK, here we go...
I'm going to start on my CP this weekend, I will have 4 8-Ways, 1 4-Way, and 1 Original Tron Joystick on the panel...(not including two track balls, and an original Tron Spinner.  When I wire up the joysticks, I am guessing that the Player 1 8-way, 4-way and Tron Joystick all need to go to the same inputs on the I-PAC, is this correct?
  8      4     T
      I-Pac...
somethig like that???
« Last Edit: July 11, 2003, 10:24:50 am by Gromet »
Tiger-Heli
    • Tiger-Heli
Re:Wiring Joysticks
« Reply #1 on: July 11, 2003, 11:41:20 am »
OK, here we go...
  8      4     T
      I-Pac...
Yep, that will work!
