Author Topic: MisfitMAME - cfg or ini files? How do I change general settings?  (Read 2195 times)
Are there any general settings for Misfit MAME?  I installed in on my cab but the resolution is a mess and I don't see a cfg or ini file or anything.  Any ideas?
severdhed
  • Last login:Today at 06:01:44 pm
  • RIP Dinosaur Hippo
Re: MisfitMAME - cfg or ini files? How do I change general settings?
« Reply #1 on: August 10, 2009, 10:29:14 pm »
i replied in your project announcements thread, but just for anyone else who runs across this thread looking for the same info..misfitmame will read a mame.ini file, just like regular mame.
« Reply #2 on: August 10, 2009, 10:58:43 pm »
It worked!  Thanks severdhed - I'm almost finished configuring everything...
garnerb350
    • Hyperspin
« Reply #3 on: August 11, 2009, 09:38:45 am »
So severd...I can just make a copy of my mame ini file and place it in the misfitmame folder and that it?
« Reply #4 on: August 11, 2009, 10:49:14 am »
That is exactly right.  D2K was COMPLETELY messed up - there were no vertical lines anywhere (no ladder sides or hammer handles, etc.) and the font was illegible.  As soon as I copied the mame.ini file to my MisfitMAME folder it fixed everything without doing anything else.  You don't have to rename the file either.
severdhed
« Reply #5 on: August 11, 2009, 04:59:59 pm »
yeah, that should work.  the only thing i would be concerned about causing problems would be under the  following sections:
# CORE SEARCH PATH OPTIONS
# CORE OUTPUT DIRECTORY OPTIONS
because of them pointing to folders in your actual mame installation...this may or may not cause problems, but you can always delete these sections out after you copy them over.
garnerb350
    • Hyperspin
« Reply #6 on: August 12, 2009, 09:22:59 am »
I did it last night...and at first it was reading my regular mame...but i straighten that out...I also took my ctrlr file ( x-arcade) and placed it also...all controls work fine...
Ummon
  • Trade Count: (+13)
« Reply #7 on: August 12, 2009, 05:06:30 pm »
Ahem. Misfitmame is only in the UI version. Hence, you can adjust things just like in MameUI.
Yo. Chocolate.
Stephen Hawking
severdhed
« Reply #8 on: August 12, 2009, 11:02:08 pm »
the misfitmame i downloaded seems to only be the command line version.  when launching mis.exe, it opens up to a list of roms, very similar to newer command line mame.  perhaps there is a UI version, but that is not the only version
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #9 on: August 13, 2009, 12:37:25 pm »
Looks to me the official misfit page has both.
Robin
Knowledge is Power
Ummon
« Reply #10 on: August 14, 2009, 05:32:02 pm »
Not .127, and certainly not the recent 'G' version, no.
Yo. Chocolate.
Stephen Hawking
Hoopz
  • Last login:Yesterday at 06:24:57 am
  • Intellivision Rocks!
« Reply #11 on: August 14, 2009, 06:30:17 pm »
edit
severdhed
« Reply #12 on: August 14, 2009, 06:58:18 pm »
crappy web page then..
i downloaded .127D version of misfitmame, it is command line only. my friend Google found it for me on the mameworld forums
you have to be a member to download the attachment
