Author Topic: w-g k7000 flyback and board question  (Read 3177 times)
speedklz
  • Last login:November 17, 2018, 12:56:23 pm
« on: August 08, 2009, 10:39:03 pm »
I have a 19inch crt (wells-gardner) with a bad board or flyback, and a good 13 inch crt can I swap the boards and flyback?
Best of the Best of the Best. Sir!
Kevin Mullins
    • Me on Myspace
Re: w-g k7000 flyback and board question
« Reply #1 on: August 08, 2009, 10:47:09 pm »
What kind of 13" ?
(make/model)
Rihgt now I'd have to say no.
speedklz
« Reply #2 on: August 08, 2009, 10:57:52 pm »
19k7901 the other monitor is a 25k713 <-- needing board and flyback
Doughbroz
  • Last login:December 05, 2019, 05:23:09 pm
« Reply #3 on: August 09, 2009, 08:16:17 am »
What kind of problem are you having with the 7901?  I ask because I have been working on one with a vertical collapse problem and have tried the following suggestions:  cap kit, resistors R98, 99, 100, & 101(including their solder pad connections), yoke wire solder connections, and the usual solder reflows.  So, I'm down to probably either a bad yoke or vertical IC.  So far I have been unable to find anyone who can tell me exactly what the yoke winding resistances should be.  The figures on mine are 2.8 and 7.5 ohms, not deducting the line loss of the ohmmeter leads.  If you can check yours, maybe we can compare notes and help each other out.   The attachment is a 7901 manual and troubleshooting chart I found by accident while searching for those yoke numbers.  Might be of some help.
EDIT:  Drat, it won't open the attachment.  Deleted it.  Sent it to your email.
« Last Edit: August 09, 2009, 08:36:27 am by Doughbroz »
Doughbroz
« Reply #4 on: August 09, 2009, 10:25:58 am »
Not having a good day.  After double checking the color code on R101, I see the one in my 7901 is a 9800 ohm resistor.  The chart I thought was for the 7901 says it's supposed to be 6800 ohm.  Checked some more and finally found the chart described as for the 7901 is actually for a 7500 series.  So please disregard the email I sent.  Back to the drawing board.
Kevin Mullins
    • Me on Myspace
speedklz
« Reply #6 on: August 09, 2009, 12:12:01 pm »
The 7901 is fine, but the 7131 has no picture and when I tried to discharge the flyback I got no POP or anything so I assume its dead, I would just as well change it all out.
Kevin Mullins
    • Me on Myspace
« Reply #7 on: August 09, 2009, 01:09:26 pm »
Now you are just confusing me.....
Earlier on you said the 19" was dead.
Then you mentioned a 25K, which is a 25" monitor.
I'm not sure what that 13" model is you are referring to.
Maybe it's a 13K4713 or 13K7301 or something like that.
WHICH MONITOR ARE YOU TRYING TO FIX ??
And no, you can not just go swapping parts around like that, especially when it comes between different size, makes, models. The parts on most of these are very specific and the chassis is designed to work on that particular size tube with that particular yoke.
There are few instances where individual components will interchange, but you have to be very specific on those. Major components like flybacks and such, usually won't.
If you need help repairing the one you are wanting to fix..... let us know.
speedklz
« Reply #8 on: August 10, 2009, 10:46:08 am »
Alright , lest see if I can shed some light on it...
The 19k7901 is good I had mesured is at 13 across so thats how I referred to it, and the 25k7131 is bad, needs new parts, I mesuered it at 19 inches.. Sorry for the confusion...
Kevin Mullins
    • Me on Myspace
« Reply #9 on: August 10, 2009, 11:47:38 am »
Ok, that does help..... you don't have a 13" at all.
Screen measurements are made diagonally across the screen.
(from bottom left corner to top right corner, etc)
The first two digits of those model numbers designate the monitor size.
19Kxxxx, 25Kxxxx which is why it confused me with all the 13" talk.
speedklz
« Reply #10 on: August 10, 2009, 07:06:13 pm »
Well guess Im gonna have to ebay for the replacement part since I cant chnge the two out.
Kevin Mullins
    • Me on Myspace
« Reply #11 on: August 10, 2009, 08:28:11 pm »
Would you rather just have it repaired?
SirPeale
  • Green Mountain Man
« Reply #12 on: August 12, 2009, 08:15:28 am »
If it doesn't discharge that doesn't necessarily mean your flyback is bad.  Could be many things.
speedklz
« Reply #13 on: August 12, 2009, 10:26:48 am »
I dont know anyone in the area where I am at that will fix them. I called a few shops but they only handle tv`s
Kevin Mullins
    • Me on Myspace
« Reply #14 on: August 12, 2009, 11:19:52 am »
"TV Repairmen"   ::)
(just kidding qrz)
Seriously....... if you are confident enough to remove the chassis from the frame, then there are plenty of people here that do repairs on monitors. A K7000 is especially common.
speedklz
« Reply #15 on: August 19, 2009, 02:08:35 pm »
Packing and shipping would be a killer on these things.. But If I can find a new neckboard and such I could just replace them.
Kevin Mullins
    • Me on Myspace
« Reply #16 on: August 19, 2009, 02:49:35 pm »
Packing and shipping on JUST the chassis and neckboard shouldn't be much at all.
You don't have to ship the entire tube and such.
speedklz
« Reply #17 on: August 19, 2009, 04:52:18 pm »
Ahhhh he says... these long shifts are killing me I was not thinking of that.. Sure I  could ship them using USPS priority mail for 4.95  ;D Now who wants to take a look at fixing this for me?
SirPeale
« Reply #18 on: August 19, 2009, 05:02:35 pm »
More like the flat rate box for about ten bucks.   They're not small, and you have to be sure to pack them right.  Do you have bubble wrap?  If not, get some.
One of these days I should shoot photos of how to wrap them correctly for shipping.
speedklz
« Reply #19 on: August 19, 2009, 05:35:37 pm »
Yea I have bubble wrap.. I ship alot of ebay stuff out, so I have all the free box sizes and your right the 10.00 is a better fit to be sure its protected right.
