Author Topic: LEDWiz not working for me... most likely "user error"  (Read 1360 times)
GAtekwriter
  • Last login:July 16, 2011, 09:55:44 am
« on: August 01, 2009, 04:30:36 pm »
All,
I've emailed GroovyGameGear, but not sure if I'll get a response on a weekend... was hoping to get my CP wired up but have run into a snag early on.  I'm having trouble getting my NovaGems lit up using the USB version of the LEDWiz.  Here are the details:
1.  I have 22 NovaGems.
2.  I have been VERY careful about handling the LEDWiz and I have it mounted on the four spacers.
3.  I did a test install of 6 buttons.  None light up.
4.  I have the U5V jumpered to the X5V terminal (it came this way from factory).
5.  I have all 6 NovaGems and their resistored-wires screwed down into terminal #s 1 to 6.
6.  I took a second jumper wire and ran it from X5V to a terminal post with 12 pairs... then used jumper wires to provide this 5V to 6 additional terminals.
7.  The 6 power wires from 6 NovaGems are screwed down to the terminal post to receive power.
8.  I inserted the USB cable into the LEDWiz first.
9.  I then inserted the other USB cable end into my powered laptop (plugged in to wall) running Vista - it then shows up in Device Manager as a working HID.
10.  None of the buttons are lit up.
Any advice?
Thanks,
Jim Kelly
http://forum.arcadecontrols.com/index.php?topic=67651.0
Franco B
Re: LEDWiz not working for me... most likely "user error"
« Reply #1 on: August 01, 2009, 04:51:29 pm »
Are you using any software (LEDBlinky etc) to light them? They won't light up just by plugging the LED Wiz in.
GAtekwriter
« Reply #2 on: August 01, 2009, 05:28:17 pm »
Are you serious???!!!!  I figured at least the LEDs would engage!
El stupido, here! :)
No, I didn't install any software... I thought at its simplest it was just a device to light up the NovaGems with 5V power... thanks, Franco - I'll look into this.
Jim
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #3 on: August 01, 2009, 10:39:55 pm »
GGG provides a basic software app which will let you turn the LED ports on and off - for testing.
Robots will kill you.
Arcade Addiction
DaveMMR
« Reply #4 on: August 02, 2009, 10:04:01 am »
Jim
Don't you wish all solutions were that easy?
And no you're not El Stupido.  It's a learning experience.  You now know to look for the simplest solution first.  Trust me - I used to be the person who'd take about the whole computer before realizing the reason the sound's not working was because the jack wasn't in all the way.
