Author Topic: need help with mame.ini and avga  (Read 2195 times)
reko19
  • Last login:July 16, 2025, 10:06:10 am
« on: July 30, 2009, 09:16:31 pm »
Trying to setup mame.ini as per Andy's instruction. Started with using Mamewah resolution tool, created all individual ini files for the games, everything was fine unitl I changed d3d to ddraw under video options in mame.ini Now some of the games are only occupying small portion of the screen. I think it is mostly limited to the vertical games, but they were fine until the last change. I am using the latest AVGA and Billabs 27"  Any help would be greatly appreciated, I am about to delete all ini files and letting mane decide on the resolution.
It looks like it is defaulting to this for games without ini or with ini that has resolution as auto.  Why the res tool didn't create an ini for pacman or digdug I am not sure
# WINDOWS VIDEO OPTIONS
video                     ddraw
numscreens                1
window                    0
maximize                  1
keepaspect                1
prescale                  1
effect                    none
waitvsync                 0
syncrefresh               0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D-SPECIFIC OPTIONS
d3dversion                9
filter                    1
« Last Edit: July 30, 2009, 09:32:35 pm by reko19 »
SailorSat
  • Last login:December 08, 2025, 05:06:00 am
    • For Amusement Only e.V.
Re: need help with mame.ini and avga
« Reply #1 on: July 31, 2009, 03:59:25 pm »
first of all, set switchres to 1 in mame.ini and see if that helps.
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
reko19
« Reply #2 on: July 31, 2009, 10:24:41 pm »
switchres is set to 1, same thing as before.
