Author Topic: Project 64  (Read 5304 times)
Vamp RN
  • Last login:September 25, 2011, 09:28:27 pm
Project 64
« on: July 30, 2009, 08:37:40 pm »
Has anyone else had trouble with launching a game from Project 64 in MaLa?  Whenever I try I get a message stating "attempt to open file failed".  My RockNESX is also giving me a message that it can't find the rom file.  I thought this was really weird since it was able to generate the list of games.  Just thinking that I may not have clicked on some option with the programs.  Thanks for any help/advice you can give.
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: Project 64
« Reply #1 on: July 30, 2009, 08:43:25 pm »
make sure you open Project64 outside of Mala first and set your settings to the right e resolution and to open fullscreen when loading a rom, now go into Mala and try again, same with rockness, also make sure you choose the right launch string from the emulator presets in Mala
Vamp RN
Re: Project 64
« Reply #2 on: July 30, 2009, 09:02:39 pm »
OK got the go to full screen when rom started option turned on (it already was by default).  This may be a stupid question, but the resolution options I found are for windowed and full screen; how do I know what to set them to?  My launch strings should be fine, I just did what I did with MAME and my ZSNES.
dungbeetle46
Re: Project 64
« Reply #3 on: July 30, 2009, 10:33:11 pm »
launch string will be different to mame etc
use
%path%\%rom%.%ext%
windowed resolution is the window you see when opening Project64 outside of Mala fullscreen is the resolution of fullscreen
set fullscreen to the resolution of your desktop, windowed doesnt matter what it is
« Last Edit: July 30, 2009, 10:36:39 pm by dungbeetle46 »
Vamp RN
Re: Project 64
« Reply #4 on: July 30, 2009, 10:44:32 pm »
Sweet!  That took care of the problem.  Thank dungbettle!  On all of my emulators I just have to hit my Esc key to exit the game and go back to MaLa, any idea how to make that happen with Project 64 and RockNESX?  Thanks again for your help.
« Last Edit: July 30, 2009, 10:46:03 pm by Vamp RN »
dungbeetle46
Re: Project 64
« Reply #5 on: July 30, 2009, 11:34:53 pm »
under other emulators put a tick in use hotkeys and also download the hacked project 64 from here
http://www.cpviewer.emuchrist.org/nintendo64.htm
Vamp RN
Re: Project 64
« Reply #6 on: July 30, 2009, 11:53:07 pm »
Thanks man!  You rock.  What does the hacked project 64 do?
dungbeetle46
Re: Project 64
« Reply #7 on: July 31, 2009, 03:53:39 am »
the hacked one exits with escape by default  but if its working with hotkeys then dont worry
cheers
Henrik68000
  • Last login:December 12, 2010, 01:54:23 pm
Re: Project 64
« Reply #8 on: August 22, 2009, 09:08:19 am »
Im running version 1.7 with the Mala hotkey 'close' in function. Works fine.
