Author Topic: J-Pac Questions - Please Help  (Read 1261 times)
slapaham
  • Last login:January 31, 2012, 05:32:32 pm
« on: July 30, 2009, 12:57:27 pm »
So I'm setting up my Xbox on my Taito Egret 2 cab with the J-Pac set-up. Trouble is, when it boots up, the picture looks all crappy and pixelated. On other occasions it obviously isn't outputting at the right resolution.
What am I doing wrong?
Which jumpers must I have set for my 15/24HZ arcade monitor?
Also, is there anyway I can damage my arcade monitor using the J-Pac? Or is it foolproof?
Thanks (in advance) to anyone who can help me! :)
swamprat96
  • Last login:January 10, 2012, 03:29:46 pm
Re: J-Pac Questions - Please Help
« Reply #1 on: July 30, 2009, 06:07:14 pm »
Your Xbox is putting out a signal for TV. The Jpac only protects the monitor but it does not convert the TV signal to an arcade monitor. You are missing a piece of hardware. Being an Xbox its outside the usual PC answer- and arcadeVGA or soft15lhz) I suspect you will need something like this http://www.arcadeparts.com/monitors/49272710.htm.
slapaham
« Reply #2 on: July 30, 2009, 07:39:17 pm »
Strange - it seems to imply on the Ultimarc website that it converts to 15KHZ...
http://www.ultimarc.com/xba.html
You did get me thinking though... if you changed the settings on your Xbox from 50MHZ to 60MHZ would this make a difference? Also, how about if you changed the settings of your Xbox to be able to output in HD would this make a difference too?
Thanks for the response! :cheers:
swamprat96
« Reply #3 on: July 30, 2009, 09:55:48 pm »
The J-pac does output 15Khz- but it does not control the picture
If you were PC based, using all ultimarc products , you'd use a J-Pac and an ArcadeVGA. From the J-Pac FAQ
IMPORTANT: It is not a scan converter so you will have to configure the VGA card to send the correct sync rate for the monitor OR you can use our ArcadeVGA card which will drive a 15Khz monitor with no special configuration.
Now because you are using an Xbox its different. But you still have to convert the picture itself to 15Khz- whih is why you are getting a poor picture.
Theres another approach here http://chrisevans3d.com/hardware/cabinet.htm
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #4 on: August 01, 2009, 05:12:00 am »
The Xbox outputs a 15Khz picture which should be compatible with an arcade monitor. If you are using our Xbox to J-PAC AV adaptor this should work.
Possible issues: The J-PAC needs to also be connected to the Xbox control adaptor otherwise it will have no power. You need to remove any red jumpers form the J-PAC sync pins to enable composite sync from the Xbox to pass through the J-PAC.
Otherwise drop me an email.
Andy
