Author Topic: ELO Touchscreen lamp issue (ET1545L-8UWC-1)  (Read 2986 times)
spjuenger
  • Last login:January 13, 2010, 02:57:08 pm
« on: July 28, 2009, 11:35:32 am »
I just received an ELO TOUCH SCREEN ET1545L-8UWC-1 that I bought on eBay.  The monitor seems to being working fine, but when I move the monitor the lamp shuts off and then comes back on a few seconds later.  It seems the slightest movement will trip the lamp.  Is this a function of the monitor or might I have a loose connection?  I'm planning on putting this in a jukebox.
« Last Edit: July 28, 2009, 11:38:03 am by spjuenger »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: ELO Touchscreen lamp issue (ET1545L-8UWC-1)
« Reply #1 on: July 29, 2009, 01:03:04 pm »
if i'm reading this correctly , ur backlight is shutting down when touched/bumped....?
no, that is not normal.  check the smps pcb for loose connections as well as the inverter pcb.
replace any domed 'lytics found.  ;)
